Bosch ROS20VSC, hose that locks on?
Forum topic by Gilley23 posted 10-31-2017 02:25 AM 319 views 0 times favorited 3 replies Add to Favorites Watch
View Gilley23's profile
Gilley23
489 posts in 404 days
10-31-2017 02:25 AM
The sander comes with a hose adapter, but the way the adapter holds on the sander via a pressure fit on an o-ring, it doesn’t hold tight. I could hose clamp it but that just doesn’t seem like the best fix.
Is there a hose that locks on securely like the dust filter does? I’ve searched and came up with zilch, only that it takes a 35mm hose.
3 replies so far
View jonah's profile
jonah
1720 posts in 3320 days
#1 posted 10-31-2017 02:33 AM
I got this 35mm hose use with my Bosch sander and my track saw. It fits tightly on the adapter.
Gilley23
#2 posted 10-31-2017 02:37 AM
- jonah
I kept looking at that one but couldn’t tell how it attached. Does it attach directly to the sander or do you need to use the hose adapter?
jonah
#3 posted 10-31-2017 03:42 AM
It attaches to the adapter. The other end fits a 2 1/2” port on a vacuum.
