Wood quality and decay
Forum topic by julio543 posted 10-30-2017 11:39 PM 511 views 0 times favorited 3 replies Add to Favorites Watch
View julio543's profile
julio543
2 posts in 448 days
10-30-2017 11:39 PM
Topic tags/keywords: lumber
Hello,
I am not sure if this is the right forum, buy I am looking for some answers in regards to lumber quality and decay. I have a lumbar frame in the basement. I noticed that some parts of the of the 2×4 have soft grooves or spots that you can easily scrub off with an object until you reach the hard spot. Is this something common ? I added a few pictures
3 replies so far
View Woodknack's profile
Woodknack
12468 posts in 2620 days
#1 posted 10-30-2017 11:45 PM
It’s not uncommon and is considered a defect although some people use it to their advantage by filling it with a contrasting color. Not worth the time with a 2×4, just cut out the bad and toss it.
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#2 posted 10-31-2017 01:59 AM
The first picture is pith, that is the very center of the tree. The second picture is beetle damage. The third picture is rot. In framing lumber the pith is generally not a problem unless the juvenile wood around it is causing excessive warp. A few beetle holes are not a problem unless so severe as to weaken the board. Rot can be a problem as it will significantly weaken the framing member. Ways to avoid these defects is to look for them when buying and reject those boards. When they show up in lumber you have brought home, try to cut out most of the problems, Set aside any defective boards and use them for the shorter stuff like cripples and headers, where you can cut out problems.
-- Bondo Gaposis
julio543
2 posts in 448 days
#3 posted 10-31-2017 02:32 AM
Thank you very much for all the replies. I spent so much time on line trying to figure all the stuff out. Those pictures are taking from two wood studs that I have in the basement ( 3 year old home). I will try to keep a close eye on that stuff, and probably at some point replace the rotten stud, as the center seems hollow.
- bondogaposis
Is any of the problems that you mentioned spreads or will it stay stagnant? Also when you say beetle damage, do you mean anything ranging from a beetle to a termite or its an actual beetle. I have not seen any bugs in the area.
