Excessive gear wear
Forum topic by Magoo2 posted 10-30-2017 12:57 AM 322 views 0 times favorited 1 reply Add to Favorites Watch
View Magoo2's profile
Magoo2
3 posts in 240 days
10-30-2017 12:57 AM
Just purchased a 34-802 Type 2. I believe it was manufactured in December 1992. Blade elevating mechanism was not working. After removing the top it was apparent that there was excessive wear on both the worm gear and gear teeth on the arbor castings. The gear teeth on the arbor casting were concave rather than straight across. Worm gear was worn as well so the teeth were not meshing. Has anyone seen this type of wear before? I’ve purchased replacement parts but I want to make sure there is not some underlying problem causing the misalignment rather than just reassembling the parts
1 reply so far
View TheFridge's profile
TheFridge
9608 posts in 1514 days
#1 posted 10-30-2017 02:47 AM
Seen it a couple times.
