Which router bit?
Forum topic by AandCstyle posted 10-29-2017 09:56 PM 719 views 0 times favorited 12 replies Add to Favorites Watch
View AandCstyle's profile
AandCstyle
3179 posts in 2463 days
10-29-2017 09:56 PM
Rich posted this review of a Whiteside router bit with a bearing at the end. The discussion of the review also mentioned another Whiteside bit with bearings at both ends of the cutter. If the RTF5200 (I am guessing this is the model Rich reviewed) does such a great job on wild grain, is there really a need for the UDP9112? I am willing to go the extra mile if it is warranted but don’t want to be crazy unnecessarily. Can anyone provide a head to head comparison? TIA
-- Art
12 replies so far
View pintodeluxe's profile (online now)
pintodeluxe
5798 posts in 3019 days
#1 posted 10-30-2017 03:22 AM
I use the Whiteside bit that is 1/4” diameter and has the bearing at the tip. It has the advantage of cutting tighter inside corners and is much less expensive.
117342 posts in 3783 days
#2 posted 10-30-2017 02:57 PM
It seems I’ve seen Charles Neil use that bit and talk about what a great bit it was I think he was using it for a flush cut bit.
View bigblockyeti's profile
bigblockyeti
5290 posts in 1926 days
#3 posted 10-30-2017 03:05 PM
Do you have a number for the 1/4” diameter bit with a bearing at the tip, that’s just what I’ve been looking for?
View splintergroup's profile
splintergroup
2437 posts in 1428 days
#4 posted 10-30-2017 04:01 PM
Art,
I have a version of the RTF5200 (RTF5125, 1/2” shank). I use it a lot and the spiral does help with squirrelly grain, but still not 100%. The nose bearings are installed on a small diameter stud, which I think I may have tweaked a tad since I can feel vibrations as I follow a template.
If I have an object that I use a template on, I usually deal with the change in grain direction by going “downhill”, the Whiteside 2715 has the top/bottom bearings so I can just flip my part+template over, raise/lower the bit, and keep the cut running downhill. This bit has two flutes but the cut is still very nice. It has a large diameter so I can’t use it in tight spaces like the RTF bit.
In my mind, the ‘ultimate’ bit is the Whiteside UDC9112 since it has the fancy cutter design and top/bottom bearings. Cost is crazy though.
View CharlesNeil's profile
CharlesNeil
2457 posts in 4076 days
#5 posted 10-30-2017 04:17 PM
The compression bits , like this one, definitely yield a superior cut and finish… pricy .. yes… worth it ,IMHO definitely
View Rich's profile
Rich
3902 posts in 795 days
#6 posted 10-30-2017 05:44 PM
I can’t provide a head-to-head comparison, Art. I can speculate based on experience with the UDFT5152 that I reviewed and with router bits in general.
The UDX9112 bits are 7/8” in diameter. That’ll make a significant difference in the cut, since the larger diameter means the bit exits the cut at a lesser angle, which will reduce the risk of tear out. The different part numbers simply distinguish top-bearing, bottom-bearing and the combination bit with bearings top and bottom. The UDFT5152 that I reviewed has a 1/2” cut diameter. A smaller diameter means the cut exits the wood at a steeper angle, and could be more prone to lifting the grain causing tear out.
The cut diameter also affects how tight of a radius curve you can cut into, so if you’re doing intricate patters, it might be a factor.
The UDX9112 has a 1-1/8” cut depth, while the UDFT5152 has a 1-1/2” cut depth. If trimming stock greater than about 1” thick is a requirement, you’ll need to consider that.
The UDFT5152 is top bearing only and costs about $45 to $55 less than the UDX9112, depending on configuration.
So, really, they are both top quality bits like you expect from Whiteside. The choice you make will come down to your needs and pocketbook.
AandCstyle
#7 posted 10-30-2017 09:11 PM
I appreciate the input. I just couldn’t bring myself to spring for the UDP9112 so I ordered the “cheap” alternative.
-- Art
View robscastle's profile
robscastle
5502 posts in 2410 days
#8 posted 10-30-2017 09:55 PM
Art,
Have a look on ebay, I bought 2x (1/2” shank) just recently so I could route forwards and backwards by reversing the template
they were yellow Yonico Brands.
The supplier is in the US
https://www.yonicotools.com/
Mind you its no compression bit! But does the job for a poor (no money) woodworker
-- Regards Rob
View jimbrown's profile
jimbrown
22 posts in 501 days
#9 posted 10-30-2017 09:59 PM
Do you have a number for the 1/4” diameter bit with a bearing at the tip, that s just what I ve been looking for?
- bigblockyeti
Woodcraft sells these bits – they should have the number, that’s where I got mine
-- JimBrown
View Rich's profile
Rich
#10 posted 10-30-2017 10:08 PM
- bigblockyeti
The 1/4” Whiteside flush trim bits are numbered RFT2100 for the up-cut, and RFTD2100 for the down-cut. There is no compression cut 1/4” bit. They are each about $38 on Amazon.
bigblockyeti
#11 posted 10-31-2017 01:09 PM
Thanks, ordered.
pintodeluxe
#12 posted 10-31-2017 05:55 PM
I have tried pretty hard to cause tearout on changing grain direction in white oak with the RFT 2100…
“No Luck Yet.” It just seems to make a clean cut every time.
