Dado set advice
Forum topic by Vrtigo1 posted 02-14-2011 06:47 AM 2081 views 1 time favorited 22 replies Add to Favorites Watch
View Vrtigo1's profile
Vrtigo1
434 posts in 3112 days
02-14-2011 06:47 AM
I bought my first dado set, a Freud SD208, about 6 months ago and am mostly happy with it. The one serious drawback is that the shims get torn up and deformed around the arbor to the point where they’re unusable. Instead of buying more shims, I’m looking at dado sets that come with a 3/32” chipper so I don’t have to shim so much when working with plywood.
I’m looking at the DW7670 which knotscot gave a positive review on. My question is, if I use the two outside blades, three 1/8” chippers and the 3/32” chipper, does that really yield a dado sized perfectly for 3/4” plywood with no shimming or is that too good to be true? I guess the second question has to be, is all 3/4” plywood really 23/32” or is there some variation? I seem to recall that the combination of shims I found worked one time didn’t work the next, but that could be due to the aforementioned deformation of my shims.
Right now, I dread having to work with plywood because it takes me 5-10 minutes to find the right combination of shims to get a good fit. I’m trying to determine if a new dado set will change that.
22 replies so far
View deucefour's profile
deucefour
285 posts in 3374 days
#1 posted 02-14-2011 07:32 AM
my limited experiance is that the plywood sizes vays slightly, but it is easy to build a jig that sets itself up for the exact width of the stock. and then you use a router and pattern bit to make the cut. I think I saw the woodwhisperer make one
hope that helps
Robert
View Don's profile
Don
517 posts in 3193 days
#2 posted 02-14-2011 07:37 AM
Most 3/4” plywood is imported and is actually 18mm in my experience. That’s a little less than 3/4”. I much prefer using a router and jig like Robert describes when cutting dadoes.
-- Don - I wood work if I could. Redmond WA.
View knotscott's profile
knotscott
8122 posts in 3496 days
#3 posted 02-14-2011 09:36 AM
Plywood isn’t overly consistent from sheet to sheet, or within a sheet, so I can’t say for sure whether or not you’ll get a perfect size dado for 3/4” plywood everytime without shims, but can say from experience that the shims on my DW7670 set didn’t get deformed as much as the ones on my SD208 did.
View Sawkerf's profile
Sawkerf
1730 posts in 3189 days
#4 posted 02-14-2011 03:35 PM
I would bet that your shims are slipping into the arbor threads during your setup and that they’re getting crushed when you tighten the arbor nut.
About three years ago, I replaced my metal shims with magnetic shims. They’re similar to refridgerator magnets and come in .010”, .012”, and .015” thicknesses. Thet stick to the chippers and blades and stay put during the setup.
View ScottN's profile
ScottN
261 posts in 2800 days
#5 posted 02-14-2011 04:10 PM
Many years ago I gave up on the dado blades and went to router bits. I would recommend buying a good set of plywood router bits. You can start and stop your dadoes where ever you like. I get perfect dadoes every time.
-- New Auburn,WI
View Pop's profile
Pop
427 posts in 4067 days
#6 posted 02-14-2011 04:33 PM
Have you looked at the Freud “Dial-A-Width” dado set? It’s pricey but a super nice set and no shims. It’s not a wobble blade but adjust straight in & out. You also don’t have to disassemble the set on the saw to make small adjustments. You just loosen the arbor nut and adjust.
Pop
-- One who works with his hands is a laborer, his hands & head A craftsman, his hands, head & heart a artist
View SnowyRiver's profile
SnowyRiver
51457 posts in 3601 days
#7 posted 02-14-2011 05:04 PM
I have magnetic shims on my Forrest dado set and they sometimes get pulled into the arbor threads also. I have even had to clean the arbor off in order to get the nut back on when changing blades. I have watched them carefully when installing but every now and then they get into the arbor threads so I am not sure what is going on either.
-- Wayne - Plymouth MN
View JJohnston's profile
JJohnston
1622 posts in 3412 days
#8 posted 02-14-2011 05:34 PM
I have a set that has 1/8, 1/16 and 3/32 chippers (an 8” “Avenger” brand from Woodworker’s Supply), and I still have to shim every time, so I don’t think having the narrower chippers will help in that regard. One thing that having the narrower chippers does help with is cutting dados for hardboard drawer bottoms: I’m currently on a sheet of hardboard that’s about 0.175” thick, and the only combination that works is 1/16 + 3/32 + about 0.020” of shim. The set warns not to use the chippers by themselves, but as long as I feed slow, there doesn’t seem to be any problem.
Anyway, I have the same troubles with my shims, so one of these days, I’m going to dispense with them and get a Freud dial-a-width.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Jeff's profile
Jeff
467 posts in 3315 days
#9 posted 02-14-2011 06:02 PM
Because plywood varies so much as knotscott says both between and within sheets, I set my dado to slightly under the size I need. Then I move the fence for a second cut to get the exact size needed. I know it takes extra work and extra tests of the cut but I can get the exact size dado I need without messing with the shims.
Vrtigo1
#10 posted 02-14-2011 08:00 PM
Thanks for the info. I’m sure that the shims are getting torn up because they’re falling down into the arbor threads. I didn’t know about magnetic shims, but now that I do I’ll probably pick up a set.
View Blue Mountain Woods's profile
Blue Mountain Woods
110 posts in 3055 days
#11 posted 02-14-2011 11:13 PM
My $.02:
For absolute ease of adjustment, ridiculous accuracy, durability and profound spiritual enlightenment, I concur with those suggesting Freud's Dial-A-Width dado set. I’ve had mine for about a year and a half, and won’t use anything else.
-- Pete ----- http://www.bluemountainwoods.com
View pintodeluxe's profile
pintodeluxe
5741 posts in 2934 days
#12 posted 02-14-2011 11:43 PM
I tend to put my shims toward the outside of the stack for ease of installation / removal.
I agree that plywood sizes vary a little bit. Even if they were consistently sized, I like the ability to add the .004” shim to allow a little room for glue. Other joints I want really tight, so I just use the .020” and the .012” shims.
I just make a 12”x12” sample board with all the common dado widths cut into it. Label each dado, and then it’s a simple matter of checking the fit with your project parts.
Best of luck whatever you decide.
Vrtigo1
#13 posted 02-14-2011 11:53 PM
I noticed that a few people have complained about their arbors not being long enough to utilize the full width of the dial-a-width dado set. I assumed those people are probably using benchtop saws, but this dado set doesn’t strike me as something someone with a benchtop saw would buy. I assume the standard arbor on a unisaw is long enough?
Blue Mountain Woods
#14 posted 02-15-2011 12:07 AM
It is… my saw is a 5-year-old Unisaw, and while a bit close, I can get the whole set on (though I usually don’t need it…..leaving out one chipper can still put me over 3/4”).
View mcase's profile
mcase
446 posts in 3250 days
#15 posted 02-15-2011 12:21 AM
Freud makes a dial in dado set that does away with shims altogether. Its design is not like the old spiral sets at all. Its is outstanding. You can make adjustments without removing the blades from the arbor. The only drawback is its around $250.00
