Danish Oil and Arm R Seal
Forum topic by Wstein posted 10-29-2017 06:32 AM 1237 views 0 times favorited 7 replies Add to Favorites Watch
View Wstein's profile
Wstein
43 posts in 1876 days
10-29-2017 06:32 AM
Guys and Gals,
A quick question. I am finishing a sapele dining room table top and I am going to use danish oil as my initial coat. I will be applying 2 coats of danish oil and letting it dry for about a week. My question is how to apply the arm r seal. I know the manufacturer has you apply a coat with a foam brush, let it briefly soak in then wipe off with a rag. Once that coat is dry, scuff sand and apply the next coat, and repeat until you have the desired coats. Since I have already applied a sealer coat (the danish oil), do I still apply the arm r seal the same?
Thanks in advance,
Paul
-- I would offer moral support, but I have questionable morals - Me, 2005
7 replies so far
View RobS888's profile
RobS888
2488 posts in 1964 days
#1 posted 10-29-2017 01:00 PM
To me you have the details reversed. I wipe off the danish oil after a couple of minutes, but let the arm-r-seal completely dry as applied, levels nicely on its own.
Some people apply arm-r-seal with a rag, so the apply several thin coats. I do several thick coats.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View HunterDS's profile
HunterDS
47 posts in 619 days
#2 posted 10-29-2017 01:35 PM
I would use a foam brush. My regiment is seal coat shellac since it closes the pores of the wood and drys fast so you can apply more coats quickly. Then I’ll brush on armrseal with the brush to make a film finish and I won’t wipe it off since it’s not penetrating the wood as much. I give it about a day between coats and very lightly sand with 400 grot.
-- Hunter, Houston TX
View Kirk650's profile
Kirk650
545 posts in 867 days
#3 posted 10-29-2017 01:37 PM
I let the Watco Danish Oil soak in as much as it will, then wipe off the excess. Be very sure it’s dry before you coat it with something else. If you don’t, the cover coat won’t dry. It actually took me two ‘mistakes’ before I realized I was not letting the Danish Oil dry completely.
View Monte Pittman's profile
Monte Pittman
29794 posts in 2457 days
#4 posted 10-29-2017 01:41 PM
I like Danish Oil, but make sure it’s dry before applying anything else. Then I use the foam brush.
View pontic's profile
pontic
626 posts in 727 days
#5 posted 10-29-2017 01:48 PM
Is Arm r seal similar to waterlox?
-- Illigitimii non carburundum sum
View OSU55's profile
OSU55
1834 posts in 2108 days
#6 posted 10-29-2017 03:19 PM
You dont need the danish oil. Arm r seal or any other poly with some dye will get the same thing faster since it will dry faster than the danish oil, and be harder. Read here
View Lazyman's profile
Lazyman
2391 posts in 1506 days
#7 posted 10-30-2017 02:44 AM
As OSU55 says, unless you are trying to get a specific color with the DO such as Watco DO stain for example, you don’t need it. Just go straight to the Arm R Seal.
