| Forum topic by Tommy | posted 829 days ago | 2172 views | 0 times favorited | 33 replies | ![]() |
829 days ago |
I’m looking for some input on what materials make good zero clearance inserts and where I can buy that material. I’d like to make them for my table saw (hitachi) and bandsaw (craftsman). I recently bought new blades for each and want to maximize my benefit from those. Any help or advise on how to create these or what material to use is appreciated. Thanks in advance to all you Jedi Woodworkers who know these answers. -- Tommy, ---- It's Never Crowded On the Extra Mile. |
33 replies so far
#1 posted 829 days ago |
I use hardboard usually but sometimes I make a more elaborate insert |
#2 posted 829 days ago |
solid wood, plywood, mdf, or some synthetic material will all work, each probably has different durability ratings but for me availability dictates what I use, when you make one you might as well make several while you are at it |
#3 posted 829 days ago |
I made mine from purple heart and curlly maple -- Dave..Pensacola Fl.........In GOD we trust |
#4 posted 829 days ago |
I usually make mine out of baltic birch plywood 1/2” thick. Solid wood could change due to humidity. Here is a pretty good video on how to make a zci in general. If it’s for a miter saw or something that requires a 1/4” thick stock I usually use 1/4” HDF. Actually I have a lot of scrap laminate flooring that i’ve kept for that very reason. http://www.shopnotes.com/issues/90/videos/making-a-zero-clearance-insert/ Kevin -- Williamsburg, KY |
#5 posted 829 days ago |
They are very easy to make. Like Kevin I usually make them from 1/2 inch baltic birch ply. I also use mdf. I use the insert that came with the saw as a template. I use double stick tape to affix the insert to the stock. I cut it to rough size on the bandsaw and then bring it to final size on router table with a pattern bit. I put set screws around the perimeter of the insert to adjust the height. I usually make several at a time. One for regular sawing, some for making joints, and some for varous dado thicknesses. For regular sawing I cut a kerf behind the back of a blade and glue in a piece of hardwood to act as a splitter. -- Glen |
#6 posted 829 days ago |
For my particular table saw, 1/2” ply works great. I drill four holes to add the ajusters I need for that last little bit of height. And a bit of paste wax on the ZCI works wonders. -- Don't sweat the petty things and don't pet the sweaty things. |
#7 posted 829 days ago |
What about making a zero clearance insert for an old craftsman 10” saw that uses a flimsy sheet of metal for the plate? -- ~Larry Columbus, OH |
#8 posted 829 days ago |
I used hardboard for mine and am very happy so far. A little tape on the bottom to get it flush works very well for me. -- Measure once, cut twice. |
#9 posted 829 days ago |
Larry: I’ve got a Craftsman contractor’s saw that uses the thin plates, and I always wondered that too. Don’t know where I read it, but some have made them out of thicker material, then rabbited around the insert so it fit flush. I haven’t studied my saw/plate yet to see how that will work out. I bought a General cabinet saw since I read that, so I might not go ahead with the C man since it won’t be my main saw. Greg |
#10 posted 829 days ago |
The last one I made, I made out of UHMW … bought in the form of a Wal-Mart cutting board. I can get a couple out of it, which works out to about $4/ea. The wood ones I’ve made get a bit chewed up by my anti-kickback pawls, which … over time … tend to get stuck IN the wood. -- -- Neil |
#11 posted 829 days ago |
My ridgid contractors ts, don’t know the exact model, insert is only about 1/8” thick and have not seen any blanks that thin. Do they make any? I haven’t seen anything that thin that I could use either. Any ideas? thanx -- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" << |
#12 posted 829 days ago |
Roger, Got planer ? -- -- Neil |
#13 posted 829 days ago |
got none of those yet. :( -- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" << |
#14 posted 829 days ago |
Ditto what Glen said. It’s actually quite easy. -- jay, www.allaboutastro.com |
#15 posted 829 days ago |
For 1/8 thickness try acrylic (perspex) -- I am not so rich to buy cheap tools. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
