"Burn Baby Burn"drum sander 16/32
Forum topic by Dansww posted 635 days ago 966 views 0 times favorited 13 replies Add to Favorites Watch
View Dansww's profile
Dansww
10 posts in 659 days
635 days ago
Topic tags/keywords: jet 1632 sander powermatic 37 drum 1791320
I have a jet 16/32 sander and I use 120 and 80 grit paper. More times than not the 120 grit paper will get burn streaks and there is no fixing it after it starts. Do you guys have a solution to the problem? Also I was looking to upgrade to the Powermatic 37 ” drum sander 1791320 am I going to have the same problems with this unit? Thank you. Dan
-- Making Antiques for the Future
View GaryK's profile
GaryK
9536 posts in 885 days
635 days ago
I did have that problem when I first got my 22/44. To solve it I just skow down the feed a little bit, and
keep the drum clean with one of those belt cleaners. The kind that is like a big eraser.
It’s been at least 3 years now and I have not had that problem since.
It probably would happen more if you were to run softwood through it vs hardwood. I can see
that ANY sap at all woudl mess things up.
25803 posts in 1297 days
635 days ago
I’ve had it happen with cherry. I don’t take a very big cut. Less than a 1/4 turn on the adjustment. I’ve never done Gary’s method of slowing it down.
View tomd's profile
tomd
216 posts in 667 days
635 days ago
I also have had it happen with cherry. Cherry tends to burn easly, taking light cuts helps but also watch out for the belt if an edge starts to ride up over itself. I run cherry though on the fast side.
-- Tom D
View Suz's profile
Suz
51 posts in 653 days
635 days ago
As for ‘fixing’ do you mean the wood, or the belt? I’ve taken the belt off the machine, soaked it in a soap solution and then brushed off the burned area with a small brass wire brush. Rinse and hang up to dry.
I’ve also removed the burned on ‘whatever it is’ by rolling the belt in a small radius in my fingers and a lot of times this streak will pop off the belt.
Also, I save my old belts to be cut up into small pieces if I need some sandpaper to hand sand some unusual profile. I’ve already cut a old belt up to make a flap sander.
-- Jim
View Pathpounder's profile
Pathpounder
49 posts in 791 days
635 days ago
I’ve had a burn sometimes when the belt loosened a bit and doubled over itself slightly. A little readjustment and tightening usually took care of it.
I agree with the small adjustments too. I usually take only 1/8 or less turns per run.
-- http://ragtimewoodwork.blogspot.com/
View rikkor's profile
rikkor
11335 posts in 771 days
634 days ago
You have to feed fairly slow and take light cuts. As Gary said, get one of those eraser things. It really helps the belt life, too.
View 8iowa's profile
8iowa
592 posts in 658 days
634 days ago
Woodworking author Nick Engler (60 books), Has also been frustrated with sanding tools, His exact comment is, “I have evaluated a great many motorized stand-alone belt sanders and belt/disc combos and find that there are none, nothing, nada, zip that run at the correct speed. It’s as if all the sanding tool engineers in the world caught the same virus (except ours, because they’re dead) and it destroyed the part of their brains that makes the connection between rpm and fpm. I really think the CDC should look into this.”
The real solution to the problem is variable speed.
View Tim Pursell's profile
Tim Pursell
389 posts in 679 days
634 days ago
I’ve got an old Ryobi And never use anything less than 80 grit. Anything finer, burns or loads up so fast it’s more effort to change the paper than use the ROS to get rid of the lines left by the 80 grit. Light cuts, like Karson says, less than 1/4 turn, unless you are sanding narrow stock. Slow down the feed at the first sign of the machine struggling to get the wood thru the head. Different woods will burn or load up at different feed rates, most of what I run is QSWO, but when I run Cherry thur the sander I slow it down even more & take even lighter cuts.
Sometimes it seems so s-l-o-w but it sure is faster than most other methods of flattening a glued up assembly, or thicnessing some figured wood. At least at the price. A big ol’ wide belt would do the job better and faster, but till the tool fairy decides to bring me one I’m going to have to put up with slow!
-- http://www.grandprairiewoodworks.com http://www.etsy.com/shop.php?user_id=6453794
View MSRiverdog's profile
MSRiverdog
39 posts in 633 days
633 days ago
“The real solution to the problem is variable speed.”
I’ve been wanting to do that with my General, 220V edge sander and Jet120V belt/disk from the first day I ran them. Is there a way to modify them?
-- http://www.riverviewwoodworking.com
View davidtheboxmaker's profile
davidtheboxmaker
372 posts in 702 days
633 days ago
I find different woods behave differently in my drum sander. The various rosewoods all seem to burn.
I have reduced to 1/12th of a turn for each lowering of the drum, and frequent use of the cleaning stick. Seems that the more oil there is in the wood the more likely it is to burn.
I also increase the feed speed so that it minimises the time exposed to the sandpaper.
I recently was using bubinga and used the planer instead of the drum sander.
8iowa
629 days ago
MSriverdog:
Why don’t you ask Nick Engler this question. He has a great depth of woodworking knowledge. He can be reached at www.shopsmith.net/forums/
View Ryan Shervill's profile
Ryan Shervill
238 posts in 710 days
629 days ago
You got me thinking…....I have a seperate variable speed router control unit….and a smal belt/disc sander…....hmmmm.
May just have to do some playing around tomorrow :)
-- If you can't set a good example, at least serve as a horrible warning... www.rarewoodcreations.com
View Sawdust2's profile
Sawdust2
1186 posts in 985 days
629 days ago
Earlier I posted a message about glue build up on the belt of a wide belt sander.
From reading this I think it is the same church just a different pew.
