connecting oneida dust deputy to hf dc
Forum topic by rmeir posted 10-28-2017 01:31 AM 799 views 0 times favorited 4 replies Add to Favorites Watch
View rmeir's profile
rmeir
17 posts in 2470 days
10-28-2017 01:31 AM
no idea what im doing wrong hooked the harbor freight dc to the oneida and i get no suction from the business end. not even a faint breeze. I might guess that the hf thing is plugged up or something but I have no idea. the hf as you know has two inlet ports and a big discharge port. I connected the dc to the top port of the oneida like you do with your shop vac and at first covered the discharge hole and i got no air flow at all. I then uncovered the discharge port and i got a real faint air flow enough to pull a little sawdust into the dust deputy but no where near where you think a 2 hp should pull. tomorrow ill check and see if the hf thing is clogged or something but other than that anyone have any ideas? Im so tired of trying to make this stuff work, I very tempted to run to rockler tomorrow and get their little wall mounted thing but my wife will kill me as she says i have spent too much money on tools already. but i dont get 300 hair dos either. oh well. if anyone has a idea let me know pls i willowe you big time.
View retfr8flyr's profile
retfr8flyr
386 posts in 1866 days
#1 posted 10-28-2017 01:48 AM
How do you have it hooked to the Oneida? Does the HF work by itself, without the Oneida? What Dust deputy are you trying to use, the small one or the Super Dust Deputy?
-- Earl
rmeir
#2 posted 10-28-2017 03:47 AM
I have tried every combo i can think of, and its not clogged just checked i must be missing something that i cant figure.
View d38's profile
d38
108 posts in 460 days
#3 posted 11-05-2017 04:15 PM
Hope you’ve gotten your issue resolved. But if not, here’s some info.
The cyclone base needs to be attached to an air tight container (trash can, drum, etc).
Top of cyclone goes to your dust collector input.
Hose from your machine goes to the side pipe on the cyclone.
As mentioned above, the Super Dust Deputy is the right match for the HF 2 hp collector. Some have used the SDD XL, to get the 6” input and output, but its really too big for the HF.
View altiplano's profile
altiplano
5 posts in 645 days
#4 posted 11-11-2017 05:40 AM
Is it a Dust Deputy?
Or a Super Dust Deputy?
The former won’t work as well with your DC. Designed more for vacuums.
