Stacked Dado for your router...
Forum topic by richardchaos posted 10-27-2017 02:29 PM 453 views 0 times favorited 4 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 286 days
10-27-2017 02:29 PM
I was looking around on Amazon for a 1/4 inch slot cutting router bit and ran across this. VERY COOL. Now if it came with a set of different depth cutting bearings it would be perfect!
-- β€œIn a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
View dschlic1's profile
dschlic1
409 posts in 1876 days
#1 posted 10-27-2017 05:59 PM
You might be able to use the bearings from a rabbeting bit.
View davezedlee's profile
davezedlee
20 posts in 731 days
#2 posted 10-28-2017 12:25 AM
Yonicos are pretty hit and miss IMO
might be worth a try, but i don’t have a lot of faith in their bearing bits
https://www.amazon.ca/Yonico-13107-45-Degree-Chamfer-X-Large/dp/B00KZM0RT2/ref=sr_1_2?ie=UTF8&qid=1509149988&sr=8-2&keywords=yonico+45
that’s my video… the replacement came with a crappy bearing, but i subbed out one of my others so decided to keep it
Amazon only allows uploading one video, but the second one from overhead shows the bearing threaded off center AND off-axis (89.5 degrees)
YMMV
View TungOil's profile
TungOil
841 posts in 401 days
#3 posted 10-28-2017 01:32 AM
I have this set:
https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html#stackable_slot_anchor
you can order a bearing set with different diameter bearings. Not the highest quality but for the minimum amount of slot cutting I do with the router it has served me very well.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
runswithscissors
2655 posts in 1931 days
#4 posted 10-28-2017 02:26 AM
I sure wouldn’t want to use the entire stack with that wimpy little 1/4” shank. Scary!
