what am I missing here
« back to LumberJocks.com Site Feedback forum
Forum topic by SawDustJack posted 02-12-2011 11:22 PM 860 views 0 times favorited 3 replies Add to Favorites Watch
View SawDustJack's profile
SawDustJack
28 posts in 2565 days
02-12-2011 11:22 PM
How to make another blog entry without adding as a comment to the current blog ??
3 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3616 days
#1 posted 02-12-2011 11:32 PM
Click on the ‘Blogs’ tab at the top left of this screen just below the LJ logo, select which blog you want to add to and follow the different boxes, add your text and bingo there is another entry in your blog.
HTH,
27251 posts in 3726 days
#2 posted 02-13-2011 12:44 AM
Jack, if you are wanting to start a new blog then simply click on the My Lumberjocks tab in the upper right corner and select new blog entry. From there you would follow the text blocks with your new blog.
18615 posts in 4064 days
#3 posted 02-13-2011 12:10 PM
Adding to a blog
1. add a comment (as you noted)
2. edit your blog: (go to the blog, and in the top right corner of the posting you will see an “edit” button) click, edit, save changes. Then post a note to say you have updated (if you wish) so people will know that you have added something
3. blog series: If the first blog isn’t set up as a series, go to edit again and add a series name. Save. Then start a new blog and select the series name. This will put the additional information as “part II”.
hope that helps.
