Unisaw 34-802 type 2 parts
Forum topic by Magoo2 posted 10-26-2017 03:49 PM 379 views 0 times favorited 4 replies Add to Favorites Watch
View Magoo2's profile
Magoo2
3 posts in 414 days
10-26-2017 03:49 PM
First time on this site. I just purchased a 34-802 type 2 at auction for $175. I was aware going in that there was a problem with the blade raising mechanism. After some investigation I discovered that both the worm gear and the gears on the arbor casting are severely worn either due to lack of maintenance or misalignment. My questions are is the saw worth fixing I’m assuming it’s going to cost somewhere around $300-$400 in parts (there are some other parts I will need) and does anyone have any Idea where I might be able to find the parts for the blade raising mechanism at a reasonable cost?
Thanks
View Loren's profile
10477 posts in 3849 days
#1 posted 10-26-2017 03:59 PM
http://owwm.org
You have to sign-up to look at the classifieds.
View MrUnix's profile
MrUnix
7050 posts in 2400 days
#2 posted 10-26-2017 06:10 PM
My questions are is the saw worth fixing I’m assuming it’s going to cost somewhere around $300-$400 in parts (there are some other parts I will need)....
- Magoo2
Tough call… spend ~$500 to wind up with an American made industry standard cabinet saw that will last you a lifetime, or spend ~$2000 or more for a new Asian import of lesser quality. I know which way I would go :)
Parts are available all over the place… those machines were made for decades and most are interchangeable between all the years with very little exception.
View avsmusic1's profile
avsmusic1
273 posts in 887 days
#3 posted 10-26-2017 07:05 PM
maybe buy another used one for parts?
Magoo2
3 posts in 414 days
#4 posted 10-26-2017 11:46 PM
Thanks Brad I’m thinking the same thing. Hopefully I can find the parts I need.
