Pocket screws from outspace
Forum topic by richardchaos posted 10-26-2017 10:41 AM 820 views 0 times favorited 9 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 408 days
10-26-2017 10:41 AM
I know this guys uses POCKET screws on his stuff BUT what kind of pocket screws are theses. NOT KREG!
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
9 replies so far
View Bumpy's profile
Bumpy
40 posts in 509 days
#1 posted 10-26-2017 11:17 AM
Porter Cable made 2 different pocked cutters in the 90’s. I have both. The first was a table top mounted system that cut the pocket then you drilled the pilot hole through the back. It was basically a trim router mounted on a pivoting base.
The other was their “Production Pocket Cutter”. It utilizes a PC 690 for the pocked and a trim router for the pilot hole.
Both units used the same cutters, from the look of the pockets, my guess is they were made with PC equipment.
View Lazyman's profile
Lazyman
2059 posts in 1415 days
#2 posted 10-26-2017 02:14 PM
+1 on the PC Production Pocket cutter. I think I saw it on Norm Abrams show years ago. It uses a router bit that makes the pocket and a separate drill bit and motor to drill the pilot hole all with one pull of a lever. I don’t think they still make it as the Kreg Foreman probably does about the same thing with a simpler and cheaper machine.
View TheFridge's profile
TheFridge
9608 posts in 1514 days
#3 posted 10-26-2017 04:36 PM
Looks like the castle pocket hole machine. Similar.
View Loren's profile
10476 posts in 3676 days
#4 posted 10-26-2017 05:50 PM
Looks like cnc cut slots to me. The long slot
allows the screws to go in at a much shallower
angle which prevents problems with the joint
shifting when the screws are tightened.
View PPK's profile
PPK
1048 posts in 837 days
#5 posted 10-26-2017 06:00 PM
+2 to Bumpy and Lazyman. But my question is why? I mean, he had to use glue or some other method to fasten the top (visible) part of the cabinet… so what’s all that pockethole work doing for him anyway?
-- Pete
richardchaos
#6 posted 10-26-2017 06:10 PM
I think you are correct, as he uses CNC to cut everything. I was thinking he could even use a bendable screwdriver shaft so he could screw straight into the wood this way…
- Loren
View cabmaker's profile
cabmaker
1735 posts in 2837 days
#7 posted 10-27-2017 12:09 PM
I have porter cables production model
It does cut a long slot similar to the picture…..thus permitting a 6 degree angle of attack for screws
richardchaos
#8 posted 10-27-2017 01:22 PM
I don’t think the porter cable Pocket Hole Cutter is available any longer is it?
cabmaker
#9 posted 10-27-2017 11:54 PM
No it is not….however you can get the identical machine in green….badged CASTLE…... Aprox. 1400.oo now…..worth every penny unless you have space for a used drill tub which can be had in that price range.
I do not know the history on the relationship between castle and porter cable…..buuuut i think porter cable bought the rights on this machine at some point. And then gave it up after some duration. Don’t really know
What i do know …..is how to use it….and that it is a very productive machine
