Project engraved brass tags
Forum topic by Greg the Cajun Wood Artist posted 10-25-2017 03:58 AM 716 views 1 time favorited 9 replies Add to Favorites Watch
View Greg the Cajun Wood Artist's profile
447 posts in 1140 days
10-25-2017 03:58 AM
Project tags…I have an electric branding iron for my completed projects and also sometimes use small 1”x3” brass engraved tags with an adhesive back that I got a good price on when i purchased 250 of them.
Often I get a request for a personalized engraved tag for commissions. I am looking for some sort of small inexpensive engraving machine that I can use to create individual brass tags no larger than a business card size.
I have no interrest in any sort of cnc machine because I would not use it.
My question is: does anyone know what type of engraver is available that creates small brass engravings?
Thanks…
-- Wood for projects is like a good Fart..."better when you cut it yourself"
9 replies so far
View DocSavage45's profile
DocSavage45
8718 posts in 3040 days
#1 posted 10-25-2017 06:39 AM
Hey Greg,
Hope you find an answer. Been having trouble with my LJ account. Cricket found a solution so I’m back.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Tooch's profile
Tooch
1808 posts in 2074 days
#2 posted 10-25-2017 09:50 AM
Greg, you could look into Pet Tag Engravers and find a bunch of different options from manual to computer generated designs.
https://www.ebay.com/i/322252652659?chn=ps&dispItem=1
Another thing would be a small Laser engraver and anodized aluminum tags:
https://www.epiloglaser.com/resources/sample-club/pet-tag-engraving.htm
Here are some tag ideas:
http://chewbarka.com/name-plates-and-business-cards-c-36/?zenid=aouirgsv2hr8k6hejrhd4rkht2
Everyone’s version of “inexpensive” is different, not sure what the budget is for this endeavor. Good Luck
-- "Well, the world needs ditch-diggers too..." - Judge Smails
#3 posted 10-25-2017 05:26 PM
Hey Greg,
Hope you find an answer. Been having trouble with my LJ account. Cricket found a solution so I m back.
- DocSavage45
Tom, glad you found a solution to your LJ account. They screwed up my old account a good while back and never got it resolved. I had to start a new one.
Any new projects lately?
#4 posted 10-25-2017 05:30 PM
Thanks for the good info. Never had a laser engraver before and it is a new area of research. I figure i will have to spend several thousand dollars for quality since laser engravers, like anything else, has a lot of cheap junk available and also alot of quality. Don’t need troublesome poor quality
Everyone s version of “inexpensive” is different, not sure what the budget is for this endeavor. Good Luck
- Tooch
View teejk02's profile
teejk02
486 posts in 1323 days
#5 posted 10-25-2017 09:48 PM
How about a “freehand” thing that you could do with a Dremel type tool (it is brass after all)? I have a few wildlife prints and they are all signed by the artists that way. Absent that, a lot of towns have trophy shops that do this stuff every day.
#6 posted 10-25-2017 11:29 PM
- teejk02
I can freehand sculpted designs on my wood projects without any problem. However i have made numerous attempts to freehand lettering with my dremel and not once did I come up with results that I was satisfied with. I do use an trophy engraver that will make the engraved brass tags for me for a reasonable price…but i usually have to wait about 5-7 days before they are ready. I just want to be able to do the professional looking engraving myself and in my shop…just a personal satisfaction thing about being able to do as much as i can
DocSavage45
#7 posted 10-26-2017 12:12 AM
A thought about engraving with a Dremel? Make some templets and copy them. Might not be as finished as you like?
#8 posted 10-26-2017 12:20 AM
- DocSavage45
Hand engraving is not an option because my hand engraving quality seems to not get any better… and I need faster and more professional results
View Lazyman's profile
Lazyman
2609 posts in 1585 days
#9 posted 10-26-2017 02:04 AM
Checkout toner transfer paper. It allows you to chemically etch metal. You print the negative of what you want to etch with a laser printer. Heat transfer the image or text to your metal and use ferric chloride to etch it.
I haven’t tried this yet but I saw this in Woodsmith magazine issue number 228. They used it to etch a decorative scroll pattern into the brass blade of a shop built miter square.
EDIT: Looks like you can purchase the plans separately. Not sure it includes the details on how to etch the pattern but you can at least see the results here
https://www.woodsmithplans.com/plan/precision-miter-square/
