Modern Square Legs for Desk Stability Question
Forum topic by Aric posted 10-24-2017 07:17 AM 1848 views 0 times favorited 11 replies Add to Favorites Watch
View Aric's profile
Aric
11 posts in 541 days
10-24-2017 07:17 AM
Topic tags/keywords: table desk leg legs square rectangle stable stability desgin modern
Hello all,
I am building a desk and had a question about leg stability. My desk is going to be about 20 inches wide, 37 inches long and 27 inches high. I wanted to build legs that were essentially two rectangles, flush with either end of the desk. See Picture attached. The leg rectangle would be 25 inches high, and 20 inches wide. My question is about the stability of this design. How thick should I make the four pieces that comprise the legs? How should I join them together? I was thinking about doing an 3/4 inches thick, 3 inches wide and using two dowels per joint. I want the desk to be stable and not to rock. I really like the sleek look and don’t want to add any cross braces if I can avoid it. What are your thoughts? Thanks!!
https://s3.amazonaws.com/vs-lumberjocks.com/oybg7k0.jpg!
11 replies so far
Craftsman on the lake
2831 posts in 3636 days
#1 posted 10-24-2017 09:21 AM
Your description of the build looks sound. If the legs are solidly attached to the top I can’t see that they’d move at all.
View Woodknack's profile
Woodknack
12430 posts in 2578 days
#2 posted 10-24-2017 04:32 PM
It’ll be fine if built from steel. Built from wood it might feel sturdy at first, assuming good joinery, but it won’t hold up and within a year or two it will be wobbly. Wood joinery just isn’t rigid enough for that design.
View TheFridge's profile
TheFridge
10705 posts in 1684 days
#3 posted 10-24-2017 04:36 PM
It might have a chance if you box jointed everything.
View RRBOU's profile
RRBOU
176 posts in 2490 days
#4 posted 10-24-2017 05:38 PM
It looks like you are incorporating a cross piece between the legs. This will defiantly degrade the stability.
-- If guns cause crime all of mine are defective Randy
View Aric's profile
Aric
#5 posted 10-24-2017 05:49 PM
Hmm… I can’t use steel and I was really hoping to keep the design as close to that as possible. What if I were to increase the thickness to 1 1/4 inches and used 3 dowels?
RRBOU, which cross piece would be reducing stability? The top or the bottom? Why would that be the case?
Thank you all for your help!
View Aric's profile
Aric
#6 posted 10-24-2017 05:51 PM
Also, which direction of instability should I be concerned with? I was thinking it would be less secure from a forward to backward movement rather than from left to right.
View jonah's profile
jonah
1913 posts in 3497 days
#7 posted 10-24-2017 06:18 PM
It will rack like crazy left to right. You need some kind of a stretcher or at least an apron to prevent left to right racking.
View Snipes's profile
Snipes
196 posts in 2443 days
#8 posted 10-24-2017 07:14 PM
I agree with others, needs a diagonal brace.
-- if it is to be it is up to me
#9 posted 10-24-2017 07:58 PM
It will hold, but if you’re unsure, instead of using dowels, use very long screws and then put dowel looking plugs over them. The top, if screwed and glued will never loosen from the legs.
View Loren's profile
10477 posts in 3846 days
#10 posted 10-24-2017 08:28 PM
I am pessimistic. At least make a plan to add
some triangular gussets later if necessary.
A general design called a “parsons table” has
been successful in wood. Worth a look for
ideas of what works.
View Lazyman's profile
Lazyman
2609 posts in 1585 days
#11 posted 10-24-2017 09:38 PM
I agree with others that the square box legs are not the strongest approach. The will tend to rack if you put lateral force without some sort of bracing. You can test this by simply making a box with without top and bottom and sit on it. Id you shift your weight will sitting, you will probably end up on the floor.
Another problem I see with that design is that if the floor isn’t perfectly flat the board on the bottom may rock like a seesaw. Generally not a problem on newer homes but not uncommon on older homes with wood floors. You may find you need to put some pads on the bottom so that it only makes contact with the floor on the 4 corners.
