bandsaw boxes
Forum topic by Mike posted 02-11-2011 01:53 PM 2630 views 0 times favorited 5 replies Add to Favorites Watch
View Mike's profile
Mike
8 posts in 3433 days
02-11-2011 01:53 PM
This is my first posting on LJ. I have a question in regards to thickness of the blanks when making bandsaw boxes. I suppose it’s a matter of personal preference but I just want to get some ideas from the LJers who make them, are we looking at 2”- 3” inches in thickness, more? less? Any and all questions answered are greatly appreciated.
Thanks
Mike
5 replies so far
View blackcherry's profile
blackcherry
3338 posts in 3968 days
#1 posted 02-11-2011 02:43 PM
Once you get past 4 inches your putting a lot of stress on such a thin blade of 1/8 t o 3/16 of a inch. I usually use the 3/16 with 3 tpi. The stress come on the curved area of the cut and remember to feed slow and steady…hope this help good luck…BC
View huff's profile
huff
2828 posts in 3430 days
#2 posted 02-11-2011 02:52 PM
Hey Mike, Pretty much any thickness will work for making a bandsaw box. A lot of times when I’m doing a bandsaw box, I’ll laminate my wood to get a thickness that I want if I can’t find a solid blank the size or in the species of wood I want. I see some of the LJ’ers use different species of wood when they laminate to get a contrast. The size of your box and the design will play into deciding your thickness also. I usually work with 3” – 4” for thickness for mine, but that’s just me and the designs I come up with. Anything will work, so have fun and hope to see some of your boxes.
-- John @ http://www.thehuffordfurnituregroup.com
View deucefour's profile
deucefour
285 posts in 3398 days
#3 posted 02-11-2011 02:52 PM
There is a really good book by lois ventura that gives the patterns and stock sizes for several boxes, i am unable to find my book right now but I remember that they were thicker than I thought they would be. the book is called building beautiful boxes with your bandsaw…...hope that helps
I just looked on amazon and their price is too high i think i paid 20-25 bucks for the book from woodcraft
Robert
View Paul Pomerleau's profile
Paul Pomerleau
309 posts in 2838 days
#4 posted 02-11-2011 03:18 PM
I go by the height of full sanding coverage of my Ridgid Oscillating Spindle Sander, which is 3 inches.
This way, it covers the entire thickness of the box nice and smooth.
My first box was about 5” thick and I had to sand one side then flip it over and do the other, and you could notice an “unevenness” in the center portion. Plus with the tight inside corners I had to use the 1/2” spindle and the nut at the top was bigger thus would hit the wood as it turned, so I have to ensure that my inside corners are not that tight so I can use wider spindles thus having no problems with the hold down nut.
So, to summarize, I use maximum thickness that my spindle sander will cover.
-- Close to Ottawa Ontario Canada
View RandyMorter's profile
RandyMorter
228 posts in 2835 days
#5 posted 02-16-2011 07:07 PM
I second pauljp’s post – I have some boxes in progress but they’re wider than the Ridgid sander so the choice is as paujp says, or try sanding by hand. I did sand ONE by hand which made me get the sander. Even then I didn’t do a great job – there’s a LOT of sanding on band saw boxes.
-- Randy Morter, Phoenix, AZ
