53 year old sears ras
Forum topic by gfadvm posted 02-11-2011 05:48 AM 1717 views 0 times favorited 18 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2658 days
02-11-2011 05:48 AM
I rebuilt an OLD craftsman RAS 2 years ago after my dad died and I inherited it.I had never used a RAS and this one had no blade when I got it so I put a blade on and trued everything up and have used it a lot since then.A friend recently visited and told me I had the blade on backwards!I obviously push it into the work instead of pulling it.This has been working well,seemsw safer to me,and Im reluctant to change.I have hold dows on the table which I always use.Should I change to pulling?The second question I have:is there any way to get a copy of the owners manual for this RAS?Thanks in advance for all the good advice I know Ill get!
18 replies so far
View HokieMojo's profile
HokieMojo
2104 posts in 3696 days
#1 posted 02-11-2011 06:05 AM
are you sure the blade was on backwards? I find it hard to believe you would ever make it through a cut.
I’m pretty sure that by pushing, you risk the blade lifting the board during the cut and causing a potentially dangerous situation (like the carriage flying at you very hard). I’d look into buying the mr sawdust book, or something like it. It will explain all the right ways to work with the saw in a much safer manner.
View harvey4804's profile
harvey4804
120 posts in 2650 days
#2 posted 02-11-2011 06:14 AM
^^^ thats what I was thinking
-- Ryan, FRMR HMM165 - HMX1 01-10
View dbhost's profile
dbhost
5705 posts in 3200 days
#3 posted 02-11-2011 06:35 AM
I am no expert here, but every RAS cut I have ever seen done is done the same was an SCMS cuts, pushing…. I am not sure how old saws were marked, but almost every saw I have seen has an arrow somewhere near the blade to show the rotation direction for the blade….
View dfdye's profile
dfdye
372 posts in 3005 days
#4 posted 02-11-2011 07:04 AM
The radial arm saw should cut on the pull, no question. The teeth should be traveling backwards when they are on the bottom, so the blade will appear to be turning clockwise when you are standing to the left of the blade. The teeth should be pointed “back” at the bottom of the blade.
If you are not sure about how to use the RAS, I just Googled a decent video that seems to be OK and has a pretty good explanation of how the saw works and how it should be used and set up. Hope this helps!
http://www.youtube.com/watch?v=SB7VYaA3wvM&feature=related
-- David from Indiana --
View Gregn's profile
Gregn
1642 posts in 2951 days
#5 posted 02-11-2011 07:07 AM
Contact Emerson Tool Co. they sent me a manual for mine. On mine I pull for the cut instead of pushing through the cut. It looks like the it should be pushed through the cut. But I was told by who I don’t remember that I should pull through the cut as opposed to pushing. It looks like I’m cutting backwards but it cuts smooth for me. Mine is a 1958 model as well and the blade guard recall for a new blade guard retrofit isn’t available for that model RAS.
HokieMojo
#6 posted 02-11-2011 07:29 AM
I know it seems wrong, but dfdye explained it right. cut on the pull. a mitersaw is a whole different beast and the two motions should not be confused.
View Pop's profile
Pop
427 posts in 3914 days
#7 posted 02-11-2011 07:57 AM
You cut on the pull. However you must use a blade with a minus hook angle. For years I didn’t and always wondered why the saw walked toward me and hogged wood. You didn’t have to pull it you had to hold it back.
Pop
-- One who works with his hands is a laborer, his hands & head A craftsman, his hands, head & heart a artist
View teejk's profile
teejk
1215 posts in 2652 days
#8 posted 02-11-2011 04:02 PM
it’s definitely a “pull” cut and the tendency to pull the work piece away from the fence explains why the RAS is not quite as accurate as a miter saw (but still good enough for 99% of what I ever need it for). I’ll try the minus hook blade next time I use mine.
definitely order the manual. I can’t find mine any more but I know they go into great detail on how to keep the thing aligned properly. there is A LOT going on with the RAS what with a movable arm, yoke pivoting for ripping, motor pivoting within the yoke for angle cuts, etc. etc. etc.
Sears sold a pile of these things. yours being as old as it is (when Sears sold some pretty good stuff), it will serve you well.
View Carl Webster's profile
Carl Webster
82 posts in 2766 days
#9 posted 02-11-2011 05:32 PM
Go to “Sears.com” Website and in the left side of the Home page you will find “Replacement Parts”. If you go to this site and plug in the model number of your saw, they may list a manual in PDF format. I own several “old” Sears Craftsman power tools made by Emerson Electric (Tablesaw, Radial Arm Saw, Lathe) and I have been able to download manuals from this site. All the Craftsman power tools made by Emerson begin with the model # 113.
-- Carl in SC
HokieMojo
#10 posted 02-11-2011 06:06 PM
teejk,
I don’t understand your post. Why do you think the saw pulls the wood away from the fence? It should actually be the opposite. You pull the carriage toward you, but the blade still spins in a direction that should force the wood against the fence (no different from a miter saw).
View Pop's profile
Pop
#11 posted 02-11-2011 06:56 PM
I didn’t understand teejk’s statement either. The blade pushes the wood back against the fence. What the minus 5 degree hook angle does is keep the blade from climbing into the wood and pulling itself forward. It acts like (and I guess it is) coming to get you. When my boys were working in my shop I had to keep telling them “hold it back! it will come forward on it’s own.” That’s back before I found out about the minus degree hook angle blade.
Pop
teejk
#12 posted 02-11-2011 07:07 PM
hokie…with the pull stroke, there is a tendency to pull the piece away from the fence on the start of the cut. at some point when the teeth engage, you are correct that it will pull back. I think that is what Pop referred to as “hogging”. maybe it was a function of the blades I was using.
but as I mentioned, the RAS cuts good enough for almost anything you will use it for (a heavy duty Crafstman my primary big tool for 15 years).
View JasonWagner's profile
JasonWagner
527 posts in 3148 days
#13 posted 02-12-2011 03:54 AM
Search the model number on Google. You should find a manual. I have a Craftsman from 1961 (50 years old!) Like everyone has said, you should be able to pull it through the wood. They aren’t the most powerfull saws and you’ll want a nice sharp blade with a negative hook angle. It will try to come toward you if you move too fast or have a bad blade.
-- some day I hope to have enough clamps to need a clamp cart!
View brianinpa's profile
brianinpa
1812 posts in 3691 days
#14 posted 02-12-2011 04:32 AM
What model number RAS do you have? There are quite a few manuals at the Vintage.org website. Select RAS in the tool type and it will show only RAS stuff.
gfadvm
#15 posted 02-12-2011 05:10 AM
Thanks for all the comments.I knew you all would help.
