orange peel problem
Forum topic by cabs4less posted 02-10-2011 05:29 AM 891 views 0 times favorited 4 replies Add to Favorites Watch
View cabs4less's profile
cabs4less
235 posts in 2996 days
02-10-2011 05:29 AM
Topic tags/keywords: question finishing
Okay I sprayed today agaisnt my better judgement and even though I added retarder to the laquer It still flashed over way to quick and I have a pretty bad case of orange peel on my new book case. Normaly I would just scuff it and respray but its to severe for that to fix it. And the problems is some spots ( left side and back) came out fine with an even texture. So do I sand it all back down and redoing all or just the bad spots and should I let it cure a couple days or does that matter. Another issue is the finish is black paint glazed with brown stain and then gemini laquer for a top coat I sprayed two coats on everything and I’m worrid about sanding to much and screwing my glaze up which came out really good. So any advice is welcome
-- As Best I Can
View Steven H's profile
Steven H
1117 posts in 3293 days
#1 posted 02-10-2011 07:33 AM
There is couple of ways that can happen.
1) Your gun is not close enough to the surface your spraying 2)Not enough air pressure 3) The gun adjustment is not adjusted properly 4) You did not thin it enough
Steven H
#2 posted 02-10-2011 07:36 AM
Theres couple more that I cant think top of my head
cabs4less
#3 posted 02-11-2011 04:16 AM
I think Its just I didnt thin it enough I did add retarder to combat the moisture in the air but the cold had a greater effect on the finish than I though it would
-- As Best I Can
Steven H
#4 posted 02-11-2011 07:07 AM
Sounds like you didn’t thin it enough and gun is not adjusted properly.
Cold weather has nothing to do with it
