Seeking Source for Scrollsaw Blades
« back to Scrollsawing forum
Forum topic by Don Broussard posted 10-21-2017 09:38 PM 651 views 0 times favorited 7 replies Add to Favorites Watch
View Don Broussard's profile
Don Broussard
3417 posts in 2122 days
10-21-2017 09:38 PM
Topic tags/keywords: scroll saw
I have a friend that has a Delta scrollsaw he purchased a few years ago and he is having trouble finding blades. I’ve included a picture of the saw and the nameplate. I would appreciate it if you know of a source for blades for this unit. Thanks in advance for passing the info on.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
7 replies so far
View MrUnix's profile
MrUnix
6188 posts in 2070 days
#1 posted 10-21-2017 09:50 PM
I’ve used a bunch of different blades, and used to use Olsen reverse tooth blades almost exclusively… until I tried the Flying Dutchmans – which is all I use now. Highly recommend them. You can find them online, even on Amazon I believe… but the source is here:
Flying Dutchman Scroll Saw Blades
(at the Wooden Teddy Bear site)
View Rick13403's profile
Rick13403
256 posts in 3375 days
#2 posted 10-21-2017 11:20 PM
I agree with Brad. I started with Olsen then switched to Flying Dutchman Ultra Reverse. These are plain end blades. Depending on how the saw was made, it might require pin end blades that are still readily available.
Rick
-- Rick - DeWalt 788 & Ex21 - www.thescrollerandtoler.com
View tomsteve's profile
tomsteve
701 posts in 1090 days
#3 posted 10-28-2017 01:44 PM
FD blades are what i use exclusively.
looks like that saw uses pinless blades, so thatsa good thing
Don Broussard
#4 posted 10-28-2017 01:55 PM
Thanks for the help! I’ve passed on this discussion to the scroll saw’s owner for his information and action.
tomsteve
#5 posted 10-29-2017 12:50 PM
might want to suggest to him to sand that table with some 600-800 grit, then apply a coat of auto wax. makes the workpiece slide a little better.
Don Broussard
#6 posted 10-29-2017 02:13 PM
tomsteve — No doubt that would help. He and I have discussed cleaning the table. Thanks for that suggestion.
tomsteve
#7 posted 11-14-2017 03:08 PM
after cleaning the table, a coat of wax helps wood move better on it.
