Cat safe finishes
Forum topic by willhime posted 10-21-2017 06:25 PM 615 views 0 times favorited 5 replies Add to Favorites Watch
View willhime's profile
willhime
117 posts in 1626 days
10-21-2017 06:25 PM
Topic tags/keywords: resource tip question trick finishing
I’m making a few cat trees/condos and my main concern is what finish to put on the wood that’ll not only be safe for the cats, but also not turn their noses up at it and flat out not use the structure. I’m using a mixture of cedar, cherry, and also raw cedar branches that I’ve wire-wheeled all the bark off of. I used watco dark walnut oil on one branch and it looks good, then I tested out the ebony stain from minwax on another and it looks good. I know shellac is safe but it’s too glossy for the aesthetic I like. For the cedar and cherry trim and shiplapped boxes, I’m thinking of using arm-r-seal interior. Another finish I was considering for the raw branches was white pickling stain because it hides so many flaws and most every woman likes white. I’d then top that with polycrylic since the pickling is water based. I’ve considered using beeswax and butcher block oil as well but it turns the wood yellow which is kind of unattractive. Thoughts ?
-- Burn your fire for no witness
5 replies so far
View Madmark2's profile
Madmark2
381 posts in 675 days
#1 posted 10-21-2017 10:15 PM
Leave it unfinished. The kitties will scratch thru whatever finish you use. Also most all paint, stain, & finishes are ‘food safe’ since the 70’s . . .
The kitties like bark.
M
View Loren's profile
10477 posts in 3735 days
#2 posted 10-21-2017 10:18 PM
Cats are said to find the smell of cedar repellent.
http://pets.thenest.com/scents-cats-hate-4180.html
If you’re committed to using cedar I think shellac
is one of the better vapor barriers, as finishes
go. It’s also easy to use.
View richardchaos's profile
richardchaos
583 posts in 466 days
#3 posted 10-21-2017 11:05 PM
Have you tried DOGWOOD?
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
richardchaos
#4 posted 10-21-2017 11:06 PM
If you are looking for something that will attract them use pile of freshly washed, dryer and folder BLACK clothes to attract WHITE cats and a fluffy hot pile of WHITE clothes to attract BLACK CATS
View Vicki's profile
Vicki
1101 posts in 3431 days
#5 posted 10-22-2017 01:56 PM
If they have front claws go with unfinished. Once they scratch the wood it will be more noticeable if there’s finish. Down the road if the scratched are too deep or unsightly it would be easier to sand with no finish to touch up.
-- Vicki on the Eastern Shore of MD
