Forum topic by maraziukas | posted 02-09-2011 04:27 PM | 1578 views | 2 times favorited | 9 replies | ![]() |
Topic tags/keywords: shaping Hey guys, I am going to make a french style dining table and faced with problem. Does anyone know how to make this type of edge (marked read in the picture)? Is there some special router bit that could be used for it? I will appreciate your advice and help. Thanks a lot. -- Maraziukas, Lithuania, https://www.marius.morazas.com |
9 replies so far
#1 posted 02-09-2011 05:20 PM |
the table i am sitting at looks almost the same, the edge is just simulated by a half round cove routed at a certain distance from the edge. |
#2 posted 02-09-2011 07:20 PM |
Here’s my guess. http://www.leevalley.com/US/wood/page.aspx?p=32679&cat=1,41182 -- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it." |
#3 posted 02-09-2011 07:24 PM |
Complicated to do it with a router and a little easy to mess up unless you want Traditionally it’s done with a very simple hand-held tool called a scratch ... and Lee Nielsen makes one too. |
#4 posted 02-09-2011 07:24 PM |
Or maybe this: http://www.leevalley.com/US/wood/page.aspx?p=62030&cat=1,41182 The only hard bit is the point right in the middle of the long rail. You might have to carefully chisel that bit and blend it in with a bit of sandpaper. -- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it." |
#5 posted 02-09-2011 08:09 PM |
Nice work Loren and Brit on your explanation on this detail. Maraziukas the Lee Valley Veritas web site is a great source of information along with all the specialty tool for all kinds of woodworking situation. If I were you I’d bookmark it for future use. Good luck on your table….BC |
#6 posted 02-10-2011 11:19 AM |
Thanks a lot guys for yours suggestions. I didn’t know that there were such amazing tools. There’s one more problem, where to find this tool in Europe for a reasonable price :) And one more question: does this tool cut well in hardwood, such as oak? -- Maraziukas, Lithuania, https://www.marius.morazas.com |
#7 posted 02-11-2011 12:48 PM |
I’ve put together a collection of links for you which I hope you’ll find useful. This first collection of links is about making and using a scratch stock: http://www.johnlloydfinefurniture.co.uk/files/p%2041-44%20FC%2092%E2%80%A6TECH%20lloyd%20JB.pdf To answer your question as to whether it will work well in hardwood such as oak. The answer is yes, you can use a scratch stock in hardwood, infact it works better than softwood. Oak isn’t the easiest wood to scratch, but it can certainly be done. If the wood has a high moisture content then that will help too as it kind of lubricates the blade when cutting. Practice on an offcut first to get a feel for the right angle and amount of pressure. Here is a link to Peter Follansbee’s blog where he talks about making and using a scratch stock and he works mainly in oak: http://pfollansbee.wordpress.com/2008/12/31/scratch-stock-moldings/ And if all of that doesn’t inspire you to make your own :-), here’s a review of the Veritas beading tool: http://www.woodworkuk.co.uk/forum/viewtopic.php?f=5&t=2702 ... and you can purchase both of the Veritas beading tools from these two companies based in England. Here’s the links: Please note: you need to scroll down the page on the second link to see the beading tool.* http://www.axminster.co.uk/veritas-veritas-beading-tool-prod22859/ -- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it." |
#8 posted 02-12-2011 06:00 AM |
A lot of interesting information here! Thanks Brit for all the links. -- "Checking for square? What madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#9 posted 02-13-2011 10:44 AM |
Wow, that’s kind of a big job all this set of suggestions! Thanks a lot! I’m definitely going to make my own, at least I will try to :) And the links are really very useful, I feel like I should learn more about googling :)) I really appreciate your help! Good luck to you! -- Maraziukas, Lithuania, https://www.marius.morazas.com |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28055 |
CNC Woodworking
212 |
Hand Tools
5407 |
Jigs & Fixtures
1418 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4756 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
