Should inside of my project get a gloss finish
Forum topic by DW833 posted 10-20-2017 01:28 AM 549 views 0 times favorited 4 replies Add to Favorites Watch
View DW833's profile
DW833
220 posts in 2082 days
10-20-2017 01:28 AM
Searched LJ for an answer to a similar question, but didn’t see anything. Adding my question to the forum.
Just refinished an oak plywood display case. It is rather large at 2’+ square and 7’ tall.
Has four glass doors on the top and middle of the case. The top two glass doors are about 16 inches.
The middle glass doors are about 3’ Two bottom small doors are wood.
Has golden oak danish oil with 3 coats of satin wipe on poly.
I’ll use two coats of gloss wipe on poly on the sides, front trim and front wood doors.
However, can’t decide if the inside should get the gloss top coat. Inside has two static wood shelves
and peg holes for adjustable shelves. Is using gloss on the inside necessary or recommended?
If yes, should all of the inside case get gloss? Including sides, back, shelves?
View Aj2's profile (online now)
Aj2
1873 posts in 1998 days
#1 posted 10-20-2017 02:28 AM
I say no to poly or varnish because it will stink. It will take forever for the finish to dry on the inside.
Shellac is ok but use fresh flakes. It’s a very nice clean smell.
Just my opinion
-- Aj
View JBrow's profile
JBrow
1366 posts in 1120 days
#2 posted 10-22-2017 12:55 AM
DW833,
I like to finish all surfaces exposed to air using the same finishing schedule. While I am not so sure it makes much of a difference when the material is plywood, I believe it helps ensure a consistent movement of moisture into and out of solid wood. Equalized moisture exchange, by my way of thinking, reduces problems of cupping and bowing in solid wood.
Since I am not sure about plywood and I am unwilling to find out the hard way, I also finish all air-exposed surfaces of plywood using the same finishing schedule. I agree with Aj2 that the interior of a closed cabinet can off-gas for quite a while after finishing. I find that after about week of open exposure to the atmosphere the off-gassing odor from oil based polyurethane is mostly gone. I am not sure how long off-gassing when oil-based polyurethane is over Danish oil would last.
View MrRon's profile
MrRon
5192 posts in 3443 days
#3 posted 10-22-2017 04:47 PM
Dust will easily wipe off a gloss finish. A dull finish will trap dust.
5174 posts in 2693 days
#4 posted 10-22-2017 07:06 PM
What AJ said…use shellac on the interior parts. Nitrocellulose lacquer can work. as will any waterborne finish. But the smell problems should keep you away from anything oil based. If, by chance, you’ve already used an oil based stain on the interior, the shellac will help seal the smell.
