Deck construction
« back to Coffee Lounge forum
Forum topic by MrRon posted 10-19-2017 04:58 PM 538 views 0 times favorited 3 replies Add to Favorites Watch
View MrRon's profile
MrRon
5275 posts in 3483 days
10-19-2017 04:58 PM
I wasn’t sure where to post this so I ask here. I’m building a deck and I have framed it all up ready for the floor boards. I stretched a string across the joists and found 2 or 3 joists are way out of line. In other words, they have a crook. I want to remove them and either reverse them so the crook faces up (bow) or replace them with a more straight piece. The joists are nailed into Simpson strongties. My question is; how can I remove the nails that hold the joists to the strongties? The nails are driven in at an angle.
3 replies so far
View stan3443's profile
stan3443
301 posts in 2515 days
#1 posted 10-20-2017 01:03 AM
A small cat’s paw nail puller works best to get them started out then use a full size one to finish. We routinely use a power plane to take the humps off
-- If your not supposed to have hair on your face......why does it grow their
woodbutcherbynight
5837 posts in 2649 days
#2 posted 10-20-2017 01:46 AM
I did same thing, used a power plane and made them flush. Been years the deck has been up and never had an issue.
View Jim Jakosh's profile
Jim Jakosh
21973 posts in 3345 days
#3 posted 10-22-2017 01:19 AM
Get one of those thin nail pullers under the steel to get the heads started and then you can pull them out with a claw hammer. I’d plane the high spot flat before putting them back in.
Or with them bowed down, you can scab a couple straight pieces along side the bowed ones to make a flat surface for the deck boards. It depends on if the scabs will show from the bottom and be objectionable.
Cheers, Jim
