| Forum topic by surfin2 | posted 862 days ago | 1229 views | 0 times favorited | 11 replies | ![]() |
862 days ago |
I’ve heard a real, real, real lot about Router lifts, how great & easy it was to raise & lower it for smooth, precise height adjustment??? What about from side to side. I would think that would be more of an issue than ease of up & down, it is for me… I’ve only heard oneperson say anything about play from his lift & he said it was the same, there was no difference… To pay more for a lift than the router itself just to raise & lowering your router makes no sense to me… -- Rick |
11 replies so far
#1 posted 862 days ago |
As they say, you get what you pay for. A router is essentially just a high-speed motor with a collet for securing a cutter, and a base. Some lifts (and bases, for that matter) are more precisely engineered and more complex than the routers they hold. For example, I have a $119.00 Bosch Colt mounted in a $400.00 Microfence plunge base, and it’s definitely worth it for doing inlay work and some other stuff. Pete -- Pete ----- http://www.bluemountainwoods.com |
#2 posted 862 days ago |
I have PC690 in a WoodPecker’s lift in a Bench Dog table … wouldn’t be without it. There isn’t any ‘side to side’ movement, and the precision adjustment is worth every penny I have invested. —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#3 posted 862 days ago |
PC 7518 in a Woodpecker lift+home brew cabinet, best addition to the shop since dust collection. -- Sawdust and shavings are therapeutic |
#4 posted 862 days ago |
How accurate are lifts for rabbits & dado’s Can you tell (Feel) it was done on increments… Is ir as clean as a what a Table saw can do??? -- Rick |
#5 posted 862 days ago |
Rick, I have a Hitachi M12V mounted in my router table…...I don’t own a router lift, and probably never will….I can’t justify spending more $$ for a lift than a router….I don’t use my router and table as much as I do my other machines, but I do use it…...Besides….I haven’t got to the point yet where I’m too lazy to reach under the table and lift it up and make adjustments….even with my bad back…....I use the little brass bars, and they work just fine….. -- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!! |
#6 posted 861 days ago |
surfin2—My router/lift is dead on … you cannot tell/feel dados or rebates were made in increments. IMHO, the dados and rebates made on the router table are cleaner than those made on the table saw … no scoring marks from the outside cutters, and no ridges in the bottom of the cut. To some degree, this is a case of using the right tool for the job. If I am doing long grooves (like the 7 foot grooves I needed in the uprights on the arbor I built a few years ago), the tablesaw is the best choice. If I am cutting rebates for a drawer box, the router is probbaly the best way to go. —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#7 posted 861 days ago |
Rick: Just a few points… You shouldn’t take a cut deeper than the width of the bit. So in many cases, you will indeed be making multiple passes. If the router lift is sitting true and with the proper insert/fence, you should have some precision in those passes. For dados/grooves, you can get more tear-out as compared to a TS dado; however, that depends on technique, type and sharpness of bit, and the type of wood. For example, I find that walnut cuts beautifully while many softwoods and laminates won’t. I used the very hard Marblewood the other day for a box and it was terrible in that regard, so it’s not just a hard vs. soft issue either, but rather grain structure. For plywood, I’d do it with the TS if possible. For rabbets, you’d normally use a scoring pass first, just to break the surface a bit before the deeper cut. But I love the router for this because I feel it’s much safer than a TS…and you don’t have to worry about sacrificial fences for it. I’m not sure what you mean by “side to side” adjustment. I assume you mean slop or play in the lift mechanism that puts a wobble in the cuts. I’ve never seen that, and I have one of the cheaper lifts (Rockler FX). As for height adjustment, it’s just about the best thing in the world to me. The more you use the router, the more you can appreciate it…especially for the fine adjustments. My next step will be to add a Wixey digital to it, but even without it it’s wonderful to be able to dial in what you need without a ton of test cuts. Above the table bit changes are great as well. -- jay, www.allaboutastro.com |
#8 posted 861 days ago |
A router lift seemed like an unnecessary waste of money – until I bought one. Now I wonder how I got along without one. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#9 posted 861 days ago |
OH, BTW, just to think of it, a router isn’t that complex of a machine and doesn’t really require that much in the way of precision. It’s a motor with a cutter on the end of it. The need for precision comes in the mechanism that holds the motor. That’s either the lift, or the types of bases (fixed or plunge) on a typical router. I would prefer getting a barebones router and putting the money into a nice lift mechanism, where the rubber truly meets the road, so to speak. IMHO, routers are actually a bit overpriced for what they are. I could justify that expense for hand-holding and interchangeable bases…but for a table, I’d look for something without all the extra stuff and put money into the lift. -- jay, www.allaboutastro.com |
#10 posted 861 days ago |
Just to underscore Jay’s advice … I bought my Bench Dog router table with a PC690 already mounted in it on CraigsList for $100. IIRC, I gave about $250 for my Woodpeckers QL350. The QL350 was a direct replacement for the acrylic plate that was in the Bench Dog router table, so I ditched the acrylic plate and the PC690 base (all I needed for the QL350 was the PC6902 motor). So for around $350, I got a router, router table with laminate top with miter tracks, an aluminum fence with T-slots, and high quality router lift with a set of inserts, a starter pin, etc. BTW—- the ability to change bits above the table is worth a lot just by itself. —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#11 posted 861 days ago |
While cutting the dado’s for the 1/2” T-track free hand with my PC 890, 1/2” straight bit & straight edge, I noticed while cutting in increments it wasn’t like it was done in one swipe. It’s like from adjusting it, it moved off center no much just enough to for me to notice(wasn’t from movement cause it went the full length of the dado) When I did the other side I left the bit extended 1/2” I put a !/4”board under the router (it stuck out acouple inches from the front & back for stability but not from the sides just alittle less then the width of the plate so it wouldn’t interfere with the straight edge, made one pass then took it off did my final pass & it came out perfect… -- Rick |
| Forum | Topics |
Woodworking Skill Share
8850 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2104 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
926 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
