Another Dumb DC Question
Forum topic by Dustin posted 10-18-2017 04:36 PM 848 views 0 times favorited 17 replies Add to Favorites Watch
View Dustin's profile
Dustin
611 posts in 981 days
10-18-2017 04:36 PM
Topic tags/keywords: question
I know everyone is sick of these, but what the heck, I’ve got a question:
I’ve been using my HF DC in combination with a cheap trash can lid separator and venting outside. Predictably, air flow isn’t great, but it’s mainly used as a chip collector for my jointer and planer (Note: I am not looking for a perfect DC solution out of this setup). Unfortunately, that separator is pretty lousy, and I have to empty the can before it hits 2/3 full, otherwise I just blow everything outside (on the plus side, it exhausts directly over a flower bed). Also, there’s still a fair amount of chips left around my planer and jointer.
My question is this: would I gain anymore suction swapping out the trash can separator for a super dust deputy? I read that cyclones tyipcally produce about 2.5” of static pressure, but those cheap lids are closer to 4.5”. I would think that reducing the pressure by ~2” would significantly aid my CFM and do a better job tidying up, but didn’t want to drop the money on a SDD for very little payout. A new DC isn’t in my future for quite sometime (and the 8ft ceilings in the current shop seem problematic to boot), so I was curious if I’d feel like I truly got my money’s worth from switching separators, or if I’d just be putting lipstick on a pig.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
17 replies so far
View AZWoody's profile
AZWoody
1420 posts in 1465 days
#1 posted 10-18-2017 04:57 PM
I did a test side by side running a molded trash can separator and an SDD and I had minimal difference between the 2.
I’m sure the separation might be better on the SDD but in terms of cfm, they were pretty much identical.
The problem is the HF blower. It’s just really not that good of a unit in terms of static pressure loss. The impeller is just too small to handle static pressure efficiently.
Dustin
#2 posted 10-18-2017 05:05 PM
I m sure the separation might be better on the SDD but in terms of cfm, they were pretty much identical.
The problem is the HF blower. It s just really not that good of a unit in terms of static pressure loss. The impeller is just too small to handle static pressure efficiently.
- AZWoody
Much obliged, Woody, you saved me some money!
Even though it takes up more floor space and offers no protection for the impeller, I’m considering reassembling the unit as designed and wheeling it close to tools to connect with a short hose. I’ve heard the back pressure generated by the filter bag has substantially less impact on CFM than a separator.
AZWoody
#3 posted 10-18-2017 05:32 PM
- AZWoody
Even though it takes up more floor space and offers no protection for the impeller, I m considering reassembling the unit as designed and wheeling it close to tools to connect with a short hose. I ve heard the back pressure generated by the filter bag has substantially less impact on CFM than a separator.
- Dustin
Well, it still may be worth it for the separation though. If you’re going to put it on a cart, you won’t be able to pump it straight outside so you would need a filter and the SDD would keep it from clogging very fast from the finer dust.
If it’s just about cost, then the trash can separator is by far the better choice or many people build their own Thien style baffle which I believe will separate better than the trash can separator.
View CharlesA's profile
CharlesA
3361 posts in 2038 days
#4 posted 10-18-2017 06:05 PM
I’m pretty happy with my Thien baffle.
View brtech's profile
brtech
1054 posts in 3163 days
#5 posted 10-18-2017 06:40 PM
Theins and DDs have been tested to be about the same in insertion loss and separation efficiency. I would have thought an SDD would be considerably better than a simple trash can separator, but this thread suggests not.
Dustin
#6 posted 10-18-2017 07:20 PM
Well, shucks, now I’m back to considering the SDD. Found this video:
https://www.youtube.com/watch?v=HaTrY-O7l5E
While it may not be the most accurate CFM measurement available, it does show an apples-to-apples testing comparison between a Thien and an SDD, with the Thien causing far more CFM loss than the SDD (and presumable my trash can lid is even worse). Hmm…
View crank49's profile
crank49
4032 posts in 3212 days
#7 posted 10-18-2017 10:27 PM
Ok, you asked so here it is.
You state that you just vent outside, so I assume you are not using the filter bag at all.
You did not state what size ductwork you are using so I will conclude it is 4” since that is the most common.
If you were running 6” duct for this unit it would probably overload the motor from excess airflow without the filter bag in place. In theory you could run 5” duct for optimum performance. Or, a 4” and a 3” and combine them right at the cyclone/baffle inlet.
Cyclone and Thien baffles both create static loss on a dust collector. The more static pressure loss they create the better the efficiency of separating dust from air. The fan on the HF collector is rather small and does not have much capacity to waste, but without the filter bag there might be enough capacity to do what you are doing.
If you don’t have enough air flow with the trashcan lid you are going to have even less with a true cyclone. The more chips and dust you separate the less airflow you will have. That’s the. nature of the beast.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#8 posted 10-18-2017 10:45 PM
Fan diameter and design must have a lot to do with a dust collectors performance. I was trying to test the CFM and air velocity on my Tempest 2hp cyclone with an anemometer. It has a 14” or 15” impeller, and I darn near lost the anemometer up a vertical run of 6” ductwork. It was all I could do to hang on to the tool.
Suffice it to say it maxed out the air velocity on my testing tool, so I concluded it was “A Lot.”
My vote is for a complete cyclone package if you can swing it. Preferably a wall mounted unit with hard piping. I messed around with a small portable Jet DC for years, and the difference between that and a full sized unit is astonishing.
CharlesA
#9 posted 10-18-2017 10:58 PM
I’ve never used a robust dust collector, but in my shop I’m pretty happy with the performance of the HF DC ported outside with a thien baffle. Probably better that I don’t know what the difference would be.
View fivecodys's profile
fivecodys
1276 posts in 1877 days
#10 posted 10-18-2017 11:08 PM
Probably better that I don t know what the difference would be.
- CharlesA
Yep. Same here!
-- I always knew I would grow old, But I expected it to take longer!
View Lazyman's profile
Lazyman
2709 posts in 1628 days
#11 posted 10-19-2017 01:25 PM
To ask the obvious question…did you check to make sure that the lid on the trash can is air tight? If you are losing suction without a filter, make sure you just don’t have air leaks. Also, if you are using one of those lids that has the right angle nozzles to create the cyclone effect in the can, those right angles add even more resistance. I think you would get better separation with a nozzle that injects the airstream from the side instead for straight down from the top with a right angle. Finally, a Thein baffle might help reduce how much dust gets swept past the separator by keeping the turbulent air away from the collected dust. Easy to make and might improve how much dust actually ends up in the can versus blown outside.
Dustin
#12 posted 10-19-2017 01:31 PM
To ask the obvious question…did you check to make sure that the lid on the trash can is air tight? If you are losing suction without a filter, make sure you just don t have air leaks. Also, if you are using one of those lids that has the right angle nozzles to create the cyclone effect in the can, those right angles add even more resistance. I think you would get better separation with a nozzle that injects the airstream from the side instead for straight down from the top with a right angle. Finally, a Thein baffle might help reduce how much dust gets swept past the separator by keeping the turbulent air away from the collected dust. Easy to make and might improve how much dust actually ends up in the can versus blown outside.
- Lazyman
Well, the lid is as air-tight as I can reasonably get it. I’m aware of the flaws inherant to the cheap design, and that’s what really drove my main question regarding whether a dust deputy would not just seperate better, but whether it would add less static pressure to the system than the current lid and thus allow for a little improved airflow.
On that note, did anyone check out the video link I posted? It does seem pretty indicative that performance from an SDD is substantially better than that with a Thien.
Also, again, I’m not trying to turn this thing into something that functions like a true cyclone system that costs 10x the price: I’m just wandering if putting a little more money in it would scale the performance according to my investment.
CharlesA
#13 posted 10-19-2017 01:36 PM
Dustin, I’m around the next 3.5 weeks before I start moving to Atlanta. If you want to see how mine works with the Thien, feel free to come by. Mine has 4” pvc ducting to every machine and vents outside. You may be able to compare to your current system, but I don’t measure my performance.
Dustin
#14 posted 10-19-2017 01:48 PM
Dustin, I m around the next 3.5 weeks before I start moving to Atlanta. If you want to see how mine works with the Thien, feel free to come by. Mine has 4” pvc ducting to every machine and vents outside. You may be able to compare to your current system, but I don t measure my performance.
- CharlesA
Charles, I’ll have to take you up on that. I was hoping to get a chance to see your shop before you relocated. And congratulations on the new position!
CharlesA
#15 posted 10-19-2017 01:59 PM
Give me a yell.
