Delta 36-943 Arbor Bracket
Forum topic by rncurrie posted 10-18-2017 03:57 PM 386 views 0 times favorited 4 replies Add to Favorites Watch
View rncurrie's profile
rncurrie
40 posts in 2595 days
10-18-2017 03:57 PM
Topic tags/keywords: tablesaw
I am in need of an arbor bracket for my Delta 36-943 table saw. Mine is finally worn out, I guess my habit of always turning the blade down after use got to it. The part is discontinued would anyone know of an after market maker of it? THANKS
-- Richard, rccarvings.com, rccarvings facebook
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#1 posted 10-18-2017 05:30 PM
Pretty much any left tilt Unisaw arbor bracket should work on your machine… you can find them on e-bay quite often, and there are/were a few being sold over at the OWWM site (in the BOYD section) that may or may not be still available. You can always put a WTB ad out there as well.
What exactly is wrong with yours?
rncurrie
#2 posted 10-18-2017 06:10 PM
The gear is stripped on the low blade end. If I lift the motor till I get past that spot it cranks up fine.
MrUnix
#3 posted 10-18-2017 06:59 PM
So I’m guessing there are a few teeth that are missing or worn down beyond hope? There are a few threads over at OWWM on how to repair those if you are so inclined… basically, it involves filling the effected area (usually by brazing) and then filing/grinding back to the correct profile. There are a couple other methods some others have used as well, such as drilling/tapping the teeth and filling with a bolt/screw instead of brazing. Would be easiest to find a replacement, but at least you know you do have a few other options as well.
rncurrie
#4 posted 10-18-2017 07:10 PM
Thanks I’ll check it out.
