Choosing rough stock for interior baseboard and trim
Forum topic by toddbeaulieu posted 02-08-2011 05:44 PM 8791 views 0 times favorited 7 replies Add to Favorites Watch
View toddbeaulieu's profile
toddbeaulieu
814 posts in 2973 days
02-08-2011 05:44 PM
Topic tags/keywords: trim baseboard
Hello,
In our mudroom, the trim is super rough, and gouged. I assume it’s rough sawn, but could be wrong. It’s painted and we love the look. Want to replace plain stained trim in another room with a similar look.
Does anyone have any experience with this? What should I ask for? I thought it was rough sawn, but when I asked for it at a specialty lumber yard they said all their wood is planed and that using rough sawn as trim would be very difficult. Our house is super old and we love the plain look with built up layers of paint.
Thank you!
7 replies so far
View WibblyPig's profile
WibblyPig
172 posts in 3243 days
#1 posted 02-09-2011 12:43 AM
Can you post a pic? It may be rough sawn or it may be a lot of paint that’s been scratched and repainted numerous times. Is there a detail on the top or is it just a 1x something? If there’s a detail, then it was surfaced at some point in time and what you have is patina.
-- Steve, Webster Groves, MO "A society grows great when old men plant trees whose shade they know they shall never sit in."
toddbeaulieu
#2 posted 02-09-2011 04:44 PM
Here’s a sample of the trim I like. Some of it’s smooth, but banged up and has the appearance of many layers of paint. That’s also a good look for us. But then there’s this obviously gnarly wood in the mix. Some even more dramatic than this one.
View jmichaeldesign's profile
jmichaeldesign
66 posts in 2752 days
#3 posted 02-09-2011 05:56 PM
That doesn’t look roughsawn, just a little rough. Or roughsawn and lightly sanded. You can get cedar from Lowes or Home Depot that is planed on one side and both edges. We use it all the time for trim at work. Its a little bit rougher than your picture. Because its surfaced on three sides you can still get tight joints.
toddbeaulieu
#4 posted 02-28-2011 05:13 PM
I’ve never seen this at HD. In fact, I looked this weekend and still can’t find any.
So, I ended up doing this the hard way. I have but a single hand plane, and it gets abused. The blade’s got nicks from nails. I used it to rough up pine trim. I also made some random gouges, dents and scratches. I think it will look good painted.
View rhett's profile
rhett
742 posts in 3636 days
#5 posted 02-28-2011 05:29 PM
The problem is where you are looking. Try scouting out your local craigslist material ads. You can find rough sawn wood cheap. If you want to put in the man hours, use a stiff bristle wire brush on pine.
-- Doubt kills more dreams than failure.
View John Ormsby's profile
John Ormsby
1283 posts in 3706 days
#6 posted 02-28-2011 05:47 PM
You can do this by carefully sand blasting the wood surface and then going over it with a fairly soft wire brush with the grain. It will look almost the same after applying a few coats of paint.
A wire brushing machine will do it also. Sometimes custom garage door companies will have a wire brush machine. It is basically a drum sander with a wire brush drum instead of the sanding drum.
Here is a link to see a wire brush machine:
http://www.supermaxtools.com/products-superbrush-bush-sander-13.php
-- Oldworld, Fair Oaks, Ca
View DrDirt's profile
DrDirt
4423 posts in 3711 days
#7 posted 02-28-2011 06:29 PM
Seems you could duplicate this in a soft pine, since you are going to paint it, using a wire wheel on a corded hand drill.
