Staining/Finishing QSWO Top
Forum topic by rwe2156 posted 10-16-2017 02:31 PM 592 views 0 times favorited 8 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
2967 posts in 1509 days
10-16-2017 02:31 PM
I am building a trestle dining table. The top will be QSWO & the base will be walnut.
Need suggestions on dye or stain the oak in a darker color to go with the walnut.
So far, I’ve seen a reference to dying first with WB red dye than staining with oil based mahogany.
Where does grain filling fall in the process? I was thinking clear filler after staining.
What has worked for you?
Thx.
8 replies so far
View Rich's profile
Rich
3030 posts in 618 days
#1 posted 10-16-2017 04:17 PM
Homestead has a PDF by Jeff Jewitt of recipes for QSWO. I did the sample 4 on a piece of mine and it came out great. He has videos of the process too, so search around for those.
http://homesteadfinishingproducts.com/wp-content/uploads/2014/05/mission_oak_6-2016.pdf
View AandCstyle's profile
AandCstyle
3075 posts in 2286 days
#2 posted 10-16-2017 10:19 PM
rwe, I agree with Rich’s suggestion if any of the colors look like what you want. Here is one I have used successfully; this is the “Oak Park” version. HTH
-- Art
View Rich's profile
Rich
#3 posted 10-17-2017 12:05 AM
- AandCstyle
That looks great, Art. You do beautiful work. The nice thing about Jeff’s recipes is that you can mix up the colors any way you want — those samples are only to illustrate. It’s just dye, seal, stain and topcoat. I use TransFast dyes instead of the TransTint. No reason other than it’s slightly less expensive and the powder is less likely to leak and make a mess :)
Rwe, the Seal-A-Cell does fill the grain a bit. Between that and several coats of Arm-R-Seal, you’ll get a pretty smooth finish. Not like a piano finish, but I think it looks pretty good. Experiment on test boards to see what you like. There’s no reason you can’t use more than one coat of Seal-A-Cell for a smoother finish. It sands nicely with 320 or 400 between coats.
Looking forward to seeing your table.
View CharlesA's profile
CharlesA
3330 posts in 1826 days
#4 posted 10-17-2017 12:09 AM
don’t know if this is dark enough for you, but I thought this finish came out really well:
http://lumberjocks.com/projects/337105
I used Bob Lang’s suggested A&C finish:
Day 1: apply walnut stain, let stand 15 minutes and wipe off
Day 2: apply Dark Walnut Danish Oil, let stand 15 minutes and wipe off
DY 3: apply one coat of Zinnser Amber shellac (I sprayed so I thinned it a bit and applied 3 coats).
View TungOil's profile
TungOil
945 posts in 524 days
#5 posted 10-17-2017 02:01 AM
For the clear grain filler, I recently used Aqua Seal Grain Filler on a mahogany table top and it did a good job of filling the grain. Was easy to apply and sand as well. Nice product. You might consider trying that product on a scrap to see if it gets you the look you are after.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
rwe2156
#6 posted 10-17-2017 02:14 PM
Rich, not looking for something quite that dark.
CharlesA – you’re right on the money. Thx I’ll definitely be experimenting with your formula.
TungOil – On the grain filler do you apply before or after staining?
TungOil
#7 posted 10-17-2017 02:40 PM
- rwe2156
apply after stainging and sealer (or first coat of finish)
View pintodeluxe's profile
pintodeluxe
5706 posts in 2842 days
#8 posted 10-17-2017 06:36 PM
Here’s some information I compiled on stain-over-dye techniques on white oak. The sky’s the limit.
http://lumberjocks.com/pintodeluxe/blog/35559
