Joining longer pieces of walnut for tabletop glueup with short jointer
« back to Joinery forum
Forum topic by NickelNick posted 10-16-2017 12:16 PM 702 views 0 times favorited 5 replies Add to Favorites Watch
View NickelNick's profile
NickelNick
2 posts in 458 days
10-16-2017 12:16 PM
I’m new to the page and wanted everyone’s opinion.
I’m doing my first glue up for a trestle dining room table with a walnut top. The top will be about 90” long. My jointer length is only 20” long… what are some alternate options or ways I can make this work to get a clean edge for my glue up? Thanks.
5 replies so far
View Carloz's profile
Carloz
1147 posts in 827 days
#1 posted 10-16-2017 12:54 PM
Get a sharp ripping blade for your table saw and you do not need a jointer.
View rwe2156's profile
rwe2156
3230 posts in 1716 days
#2 posted 10-16-2017 12:57 PM
First, use a straight edge guide and a high quality glue line rip.
After that, the only way I know to do it is by hand with a jointer plane.
View Aj2's profile
Aj2
1948 posts in 2033 days
#3 posted 10-16-2017 01:33 PM
Bring them over to my shop and I’ll joint them for you my jointer is 99 inches long.
-- Aj
View Loren's profile
10477 posts in 3883 days
#4 posted 10-16-2017 02:17 PM
You can build an outfeed table extension
for jointing longer pieces more successfully.
Even with an extension table a 90” is still
pretty long though. The time spent designing
and making such a jig could be used in
other ways.
A router table can also be set up for jointing.
It will take some time and insight to make
fences straight enough to joint 90”
edges this way however.
I would not be optimistic about ripping joints
that long on a table saw.
Considering the price of the material it might
be prudent to consider investing in a
jointer plane.
View TungOil's profile
TungOil
1080 posts in 730 days
#5 posted 10-17-2017 02:23 AM
another option is to get a decent straight edge (a well joined board will do) and a good flush trim bit for your router and clean up the edges that way.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
