Help with funky 45* tenon
Forum topic by BenDupre posted 10-15-2017 11:17 PM 777 views 0 times favorited 11 replies Add to Favorites Watch
View BenDupre's profile
BenDupre
689 posts in 722 days
10-15-2017 11:17 PM
Hi Lumberjocks,
I am building a corner desk. Mission style: therefore mortise and tenon.
The front apron, being a corner desk, is 45 deg. to the leg. I am trying to work out how to make this oddball tenon. Here is my test piece:
I basically sculpted this using my table saw with blade tilted, a pullsaw, and chisel. It’s less than exact and the process is not repeatable. Has anyone seen a good youtube or article on how to pull this off reliably? Seen a jig that can do it? I have a tenonning jig but darn the thing it will not tilt over to 45. It only tilts back to about 60.
Thanks for any tips!
-- The problem with communication is the illusion that it has occurred. – George Bernard Shaw
11 replies so far
View CharlesA's profile
CharlesA
3355 posts in 2031 days
#1 posted 10-15-2017 11:20 PM
You might get some ideas here: https://www.youtube.com/watch?v=FXyN1V4IgMg
View Loren's profile
10477 posts in 3882 days
#2 posted 10-15-2017 11:40 PM
You’ll have to take some elaborate steps if
you want to machine the whole thing.
If you can bring yourself to commit to sawing
the shoulders by hand, cutting the cheeks is
not difficult by machine. The can be cut on
the band saw, either freehand or by running
a 45 degree angled jig against the fence.
On the table saw a 45 degree block can be
clamped to the fence of a cut-off box. A
large hole bored through the block makes
it easy to clamp the work to it.
The shoulders can of course be sawn on the
table saw using 4 different setups. The
chances they will line up very well don’t
seem good to me. Any way you do it, you’ll
likely need to refine the shoulders with a
chisel.
Radial arm saws can excel at this sort of
joinery too. Still a lot of setups for just one
desk though.
View pottz's profile
pottz
3805 posts in 1218 days
#3 posted 10-16-2017 01:07 AM
or you could spend a few thousand and buy a multi router!i think youll get there whatever way you choose buddy,you always do!cant wait to seethe end result.
View Jim Jakosh's profile
Jim Jakosh
21953 posts in 3339 days
#4 posted 10-16-2017 02:07 AM
I’d do them on the milling machine, but if you don’t have one, the table saw will do a nice job. Make jig to fixture that leg at 45 degrees to the table so that the base of the jig is wide enough and longl enough to be stable passing by the blade. Clamp that piece in there and slide it across the blade in increments until you have the right width. If the base is wide enough, you can slide it by at 90 degrees to the first cut and do the whole thing without taking it out of the jig. It would be much like a sled but not riding is the miter slot.
cheers, Jim
View AandCstyle's profile
AandCstyle
3184 posts in 2491 days
#5 posted 10-16-2017 10:40 PM
Ben, another option is to use slip tenons and cut the mortises with a router. FWIW
-- Art
View TungOil's profile
TungOil
1079 posts in 729 days
#6 posted 10-17-2017 02:09 AM
+1 on loose tenons. I would not recommend cutting an integral tenon at more than a 30 degree angle for strength reasons. Generally 30 degrees is the most you want to go before you compromise the strength of the tenon too much. The loose tenon eliminates the cross grain issue that would weaken a standard tenon.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View jonah's profile
jonah
1966 posts in 3532 days
#7 posted 10-17-2017 02:52 AM
+1 for loose tenons in this application. You want to treat it like a miter spline, which you set up with the grain at an angle to the normal grain of the boards. This is basically a funky miter joint.
BenDupre
#8 posted 10-22-2017 03:15 PM
Okay so after a straight up couple weekends of puttering with this problem (and thanks to all those suggestions) I found a method that I can repeat. Thanks to Loren for the suggestion of building a 45* jig. Basically does what my cast-iron tennon jig cannot: angle to 45. So far I used my combination blade and just bumped the rip fence over 1/8 at a time. I can pull out the dado but I only have four of these to cut.
- Loren
It looks like this:
The outside shoulder is just a little fuzzy when cut this way but I can deal. I will cut the haunches with a handsaw and refine if needed with a sharp chisel.
View waho6o9's profile
waho6o9
8539 posts in 2811 days
#9 posted 10-22-2017 03:20 PM
Interesting, looks like a good solution congrats!
View bondogaposis's profile
bondogaposis
5147 posts in 2585 days
#10 posted 10-22-2017 03:56 PM
This one area where hand tools excel. If you can draw the lines on the board and then cut the line. Clean up with chisels and shoulder plane. You could have the joint cut in less time than it would take create and elaborate jig on the table saw. A jig could be worth it if you have a lot of these to make, for just a few, I would use hand tools.
-- Bondo Gaposis
BenDupre
#11 posted 10-22-2017 05:11 PM
- bondogaposis
I believe you are right, and I tried, however I just didn’t have the right kind of miter box to saw the shoulders accurately at 45 deg I also made a version on the bandsaw but that was not cutting square because of the blade drift.
FWIW I also could not brain out how to make a 45deg mortise into the apron (floating tenon approach) on my mortising machine because it was just too long.
