What am I doing wrong with my Jointer?
« back to Joinery forum
Forum topic by PeteK posted 10-15-2017 07:31 PM 2753 views 0 times favorited 41 replies Add to Favorites Watch
View PeteK's profile
PeteK
28 posts in 876 days
10-15-2017 07:31 PM
Hello all. Rookie woodworker here. I just got this Delta 6” Benchtop Jointer and I am attempting to make a flat panel out of 1×4 boards. They were already pretty close to flat on the edges but I wanted a no gap, seamless panel. But it seems the more I run the boards on the jointer, the more convex they become. So like when two boards are up against each other, there is a gap at the ends. What am I doing wrong? I am applying pressure on the outfeed side as I push through. I tried deeper cuts and shallower cuts but I keep getting further and further away from being flat. I’m confused.
41 replies so far
View PurpLev's profile
PurpLev
8548 posts in 3884 days
#1 posted 10-15-2017 07:39 PM
you might be just suffering from snipe (Edges getting overly cut), how is the center of the boards? flat and true?
usually you want to joint boards longer than the final result (if you want 30” final boards, you would want to run boards that are 32”+ long so that you can trim the ends and get you true 30” flat boards at the end)
117417 posts in 3812 days
#2 posted 10-15-2017 07:44 PM
Your problem is that your trying to joint the convex side of the board and it rocks from one end to the other if the other side is straight then take it to the table saw and put the straight side up against the fence and take just enough off to remove the convex bump then joint as necessary .
View MrUnix's profile
MrUnix
7106 posts in 2434 days
#3 posted 10-15-2017 07:44 PM
Here is a good place to start: Jointer Problems, Causes & Fixes
View Loren's profile
10477 posts in 3883 days
#4 posted 10-15-2017 07:48 PM
Before you start, put a straight edge on
each edge to be jointed to determine where
to remove stock. An edge will often be
either too hollowed or too bellied to straighten
in one pass on the jointer. If the edge is
hollow, partial passes from each end remove
the excessive hollow. If the edge is bellied,
partial passes in the center of the board
remove the belly. When you can hold the
straight edge up to the edge and it is close
to straight, then one pass will make it straight
if your technique is good.
#5 posted 10-15-2017 07:50 PM
Good to see your post-Sharon I guess I’ve missed seeing your post lately.
Lorens approach works great too.
View Kirk650's profile
Kirk650
585 posts in 984 days
#6 posted 10-15-2017 09:06 PM
When running the board edge across the jointer, press down on the middle of the board. That will help with getting the edge flat, or as I prefer, slightly convex.
PeteK
#7 posted 10-16-2017 01:24 AM
- a1Jim
Well, that is exactly what is happening, but I still am not sure how I got to there. As I said, it was pretty close to a flat edge to begin with and the more I ran the board through the jointer, the more convex it became.
I thought maybe snipe, but I always thought that would be more pronounced.
View Gaffneylumber's profile
Gaffneylumber
103 posts in 1064 days
#8 posted 10-16-2017 02:33 AM
Have you checked to make sure your outfeed and indeed tables are coplaner?
-- Grayson - South Carolina
PeteK
#9 posted 10-16-2017 02:39 AM
- Gaffneylumber
Well, they are both level. I’m not sure the outfeed is adjustable.
View RobS888's profile
RobS888
2520 posts in 2080 days
#10 posted 10-16-2017 02:49 AM
- Gaffneylumber
Well, they are both level. I m not sure the outfeed is adjustable.
- PeteK
How hard are you pressing down? If you push a board flat it will come out the same shape, but with a shave. I made some bananas when I first tried jointing. It is more of a guiding operation not a forcing operation.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
PeteK
#11 posted 10-16-2017 03:49 AM
- Gaffneylumber
- PeteK
- RobS888and
Was pushing kind of hard. I guess i dont really know the proper pressure to push down, but it makes more sense to just sort of guide through
View AlaskaGuy's profile (online now)
AlaskaGuy
4983 posts in 2544 days
#12 posted 10-16-2017 05:12 AM
How long are the 1×4’s ?
View Andybb's profile
Andybb
1599 posts in 839 days
#13 posted 10-16-2017 05:28 AM
I just spent an evening dialing in my 6” Delta. I’m no expert, but here’s what worked for me.
First, make sure the jointer is setup up properly to eliminate anything but human error before moving on.
The outfeed table is only adjustable with shims.
1. When the infeed table is as high as it can go it should be level with the outfeed table. Also make sure it’s level on the back (fence side) and front side (switch side). I had to shim the outfeed table up just a touch by removing the 4 bolts and putting a shim under the front 2 bolts.
2. Then, make sure the knives are adjusted correctly. Some say that when you rotate the knives with a straight edge on the outfeed table they should pull the straight edge forward 5-7mm. That always gave me snipe at the tail end of the board. This was caused by 2 things. One being that the infeed table was slightly higher than the outfeed. The other reason was that the blades were adjusted to pull the 7mm. It wasn’t until I saw something here that said this was incorrect and that the knives should be adjusted so that they are flush with the two tables. Use the little latch that flips up which will lock the blades in their highest point of travel. Your straight edge should glide across the tables and blades smoothly without touching the blades.
3. Then, make sure your fence is 90 degrees to the tables.
After doing those things in that order all my issues went away and I could work on my technique, which is just as important as the above but can’t be done until the machine is trued up.
Start with scrap wood that you know to be flat and is about 5” inches wide. With the tables and blades aligned and set to zero it should pass over the blades and remove nothing. Then adjust it until you can just hear it kiss the wood. Then back it off ever so slightly until you hear nothing again. Loosen the screw on the indicator and set it to zero then tighten it. Use chalk or pencil lines on the bottom of the piece and slightly adjust the blade height so that it takes off only a thin sliver of wood. The pencil lines should be evenly removed across it’s width. If they are not then your blades aren’t aligned. Fix that. Then, if you get snipe it means that the board is dropping off of the infeed table onto the blades and they, the tables, are not coplanar. Go back and fix that.
Now you can work on your technique. Put pressure on the piece as you move it across the infeed table keeping very slight pressure on the outfeed side.
Then follow Loren’s directions
- Loren
Like I said, I’m no expert but it worked great for me. When I set the dial to 1/32 and used my calipers it took off exactly 1/32. Flat boards, no snipe.
-- Andy - Seattle USA
View rwe2156's profile
rwe2156
3230 posts in 1716 days
#14 posted 10-16-2017 01:07 PM
- Kirk650
I wouldn’t do this ^ especially when face jointing all you’re doing is simulating a planer.
One mistake I made as a newbie was putting to much down pressure on the wood over jointer head. The only pressure should 1) over the outfeed table and 2) behind the cutterhead on the infeed (which is more to keep the wood moving than push down on table).
I recommend using a push block with heel rather than a standard push block, which often makes you put excessive down pressure right. You don’t want to flex the wood you want it to take off the high places. This is especially important when face jointing where the wood flexes much more.
View jonah's profile
jonah
1971 posts in 3534 days
#15 posted 10-16-2017 01:50 PM
Ditto. You want to be pushing down very hard on the outfeed side to make sure the wood registers off that surface. That will make the board conform to that (flat) surface, rather than bowing up and down as your pressure changes.
You never push down right over the cutterhead.
showing 1 through 15 of 41 replies
