Cabinet layout and design software that generates material list and cutlist?
Forum topic by Vrtigo1 posted 02-07-2011 06:44 AM 10988 views 1 time favorited 7 replies Add to Favorites Watch
View Vrtigo1's profile
Vrtigo1
434 posts in 2898 days
02-07-2011 06:44 AM
I am fed up with my current workbench situation in my garage. They are built out of “2 by” stock and plywood, and they are not exceptionally flat or square. I want to replace them with a series of cabinets.
Here is a quick mockup of what I have in mind. This is mostly to scale. I have 19’ of wall space. There are 6 cabinets, each 30” wide, a 24” cabinet in the middle that my miter saw will sit on, and my RAS will go out on the right side and sit so the table is flush with the countertop. I am planning to put a double layer of 3/4 MDF on top for a work surface.
I’m trying to find something that will let me input dimensions and materials and give me a shopping list in terms of how many sheets of plywood and how many BF of lumber I need, as well as a cutlist. I have used CabinetCruncher, and it works pretty well, but is expensive ($150, seems expensive to me, maybe that’s just what the going rate is though).
My primary concern is getting a materials list together that includes everything (lumber, hardware, etc) before I begin this project so I can make sure I have an accurate budget. Does anyone have any suggestions or comments on the design I’m looking at?
Edit: here is a direct link to the image, I’m not sure how to tell the forum not to resize it.
7 replies so far
View wseand's profile
wseand
2796 posts in 2949 days
#1 posted 02-07-2011 07:52 AM
I think Sketchup has a parts/cut list app you can install in it but I have never used it. Do a Google search for it and see if this is what you are looking for.
View Dez's profile
Dez
1166 posts in 3984 days
#2 posted 02-07-2011 08:13 AM
Something free that i have used is eCabinet
It may be more than you are looking for but it is free and gives you what you are looking for (and more besides)
There is a little bit of a learning curve, it is a cabinetmakers design system but for cabinets I think it was easier to learn and use than Sketchup.
-- Folly ever comes cloaked in opportunity!
27251 posts in 3729 days
#3 posted 02-07-2011 02:15 PM
Vrtigo, you might want to take a look at Cutlist. It is a program designed primarily for creating a materials list for sheet goods but it also handles rough/dimensional lumber as well. The silver edition is $89 (what I use) and is limited to 50 individual parts. This can be circumvented by breaking up your cabinets into multiple projects.
With the plugin that Bill mentioned you can interface it with Sketchup to take your design and produce a list of parts.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3620 days
#4 posted 02-08-2011 06:10 AM
You may want to check out Daltxguy’s blog (http://lumberjocks.com/topics/9435) where he talks about the very useful cutlist plugin he created for Sketchup. I’ve used it and it is an incredibly useful bit of software. I highly recommend it.
View John 's profile
John
253 posts in 3309 days
#5 posted 02-08-2011 06:35 AM
I’ve been using Cutlist Plus for years. Also allows you to customize your material handling and hardware.
-- John
View MikeDilday's profile
MikeDilday
10 posts in 366 days
#6 posted 08-22-2017 02:10 PM
I use cabinet planner. It works and handles cutlsts and quotes.
-- Michael Dilday, Suffolk, Va.
View ScottM's profile
ScottM
597 posts in 2053 days
#7 posted 08-22-2017 02:47 PM
MaxCut is what I use. Creates and displays cut diagrams and cut list reports. Oh, and it’s FREE!
