Replacing power switch on Delta Contractor Saw 36-9XX
Forum topic by Praki posted 02-07-2011 06:03 AM 10137 views 0 times favorited 16 replies Add to Favorites Watch
View Praki's profile
Praki
199 posts in 3997 days
02-07-2011 06:03 AM
Topic tags/keywords: question tablesaw
The power switch on my table saw, which was quite temperamental from day 1, finally quit on me. I opened it up and the switch internals were just black and fully corroded. Now for the stupid part of this question! In my haste and overconfidence, I memorized the connections and removed the old switch and put in the new switch and brought out the multimeter to test. To my surprise, one pair of this switch as always closed and I had sort of assumed that it was a two-pole switch. If anybody is curious, here is a picture of this switch.
I have grounded green, connected white to the terminals which are always closed and black to the other pair. I am not quite sure the original wiring was this way. I am probably stressing on this too much, but I would like to make sure that I am not missing anything.
Does anybody know if Delta has a wiring diagram for this switch? Perhaps someone replaced the switch recently and took a picture, unlike me!
Thanks
-- Praki, Aspiring Woodworker
16 replies so far
View Carl Webster's profile
Carl Webster
82 posts in 2799 days
#1 posted 02-07-2011 06:20 AM
Is the saw wired for 240 Volts or 120 Volts?
-- Carl in SC
Praki
#2 posted 02-07-2011 06:23 AM
120 volts
Carl Webster
#3 posted 02-07-2011 06:35 AM
My guess is that this is a single pole switch and the white wire (neutral) is closed always and the black wire (hot)side is the only side that is switched. If the saw was wired for 240 Volts a double pole switch would be the norm with both sides of the switch “switched”.
-- Carl in SC
TopamaxSurvivor
18272 posts in 3676 days
#4 posted 02-07-2011 06:46 AM
The white is probably connected to operate a pilot light when the saw is on or they use the same wiring harness with a 240 volt when they use a 2 pole switch. Haven’t done it, just guessing.
Praki
#5 posted 02-07-2011 03:02 PM
Thanks guys. I guess I will stop stressing about it as the hot side is switched. So, this also means that I need a new switch if I were to wire the motor for 240?
View Stormin's profile
Stormin
193 posts in 2790 days
#6 posted 02-07-2011 03:45 PM
Yes just like TopamaxSurvivor said If you wire the motor 240 volt you need a 2 pole switch. Make sure you use a motor rated switch.
-- I started off with nothing I have most of it left
View Alan S's profile
Alan S
181 posts in 3318 days
#7 posted 02-07-2011 05:52 PM
I have to disagree with everyone’s take on this switch. I have the same one on my saw and it is meant to be wired for EITHER 120 or 240 v operation. I had to order this exact replacement switch for my delta contractor saw because the original one had a mind of its own. If one of the pairs on the new switch is connected in both switch positions, I think you’ve got a defective switch. If you are only ever going to be wired for 120, just be sure you wire your new switch so the hot lead is the one that gets disconnected. Otherwise, I’d get a properly operating double pole switch.
Alan
Praki
#8 posted 02-07-2011 06:13 PM
Considering how finicky these switches are, Alan’s theory is starting to make sense to me – I have got a defective switch. It might not be a bad idea to replace the whole switch box with something better. After all ,you do want the saw to stop when you turn the switch off.
Praki
View ajosephg's profile
ajosephg
1880 posts in 3562 days
#9 posted 02-07-2011 11:42 PM
I’ve been thinking about this and I agree with Alan. Not a big deal if you never connect it to 240, but could be bad news for a future owner should you sell it and he/she decides to use with 240.
-- Joe
View oluf's profile
oluf
260 posts in 3040 days
#10 posted 02-08-2011 03:58 AM
I have a Delta 10” contractors saw 34-444. I went down and checked the switch. It is a DPST switch. The white is connected to one side and the black is connected to the other side. Both sides are open when the switch is off and conduct when the switch is on. The motor on this saw is a one and one half HP, 110/220 volt and is now wired for 110 volt. If I changed the motor connections I would not have to change the wires on the switch. I dont use the switch to turn my saw on or off. I built a magnatic controller with push buttons for start and stop. There is an outlet plug on the side of my controler that the saw cord plugs into. The original saw switch stays in the on position all the time. I am sorry. I went back and looked at the picture of your switch. It is not the same as mine. Mine is a toggle switch, not a rocker switch.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
TopamaxSurvivor
#11 posted 02-08-2011 05:24 AM
deke How does the paddle keep the power off if it goes out?
TopamaxSurvivor
#12 posted 02-08-2011 06:35 AM
Yeah, most motor starters are magnetically held closed. I looked at the paddle switch link, it didn’t say anything about it, so I thought it was a mechanial switch. That is a good idea for any equipment like a table saw.
Praki
#13 posted 02-08-2011 06:32 PM
Joe – anybody who buys secondhand machinery should be careful enough to check these things out. But, I will keep it this mind and be sure to mention it.
oluf – thanks for taking the trouble to look. I am going to replace this whole switch with a safer one. Can you provide some details of your magnetic switch? Is it something similar to what Grizzly sells on their website for around $50?
deke – your saw looks exactly like mine – only way cleaner :) I have a paddle switch on my router table that looks similar to what you have on your saw. I might do just that.
View Dan's profile
Dan
3630 posts in 2881 days
#14 posted 02-10-2011 05:27 PM
The Switch on my Delta Contractor saw went out and the switch on my Delta drill press went out. I replaced them both with a 30 amp rated single pole switch. Have been running them both with these switches for a while and have had no problems.
-- Dan - "Collector of Hand Planes"
View Nick11's profile
Nick11
1 post in 2407 days
#15 posted 10-25-2011 02:58 AM
Deke,
So How did you attach that switch to the table saw?
I’m replacing the toggle switch on my Delta 34-444 (3rd one in 10 yrs) and I’m replacing it with a similar switch.
Thanks,
Nick
