Bent Lamination or straight cut for rocking horse rockers....
Forum topic by RobH posted 268 days ago 371 views 0 times favorited 6 replies Add to Favorites
View RobH's profile
RobH
303 posts in 578 days
268 days ago
In case you have not noticed, I have way too many irons in my shop fire.
I am supposed to be working on a rocking horse for my sons. I am to the point of doing something about the rockers. I need to get out my router trammel and do some curve cutting for the bunk beds, so I thought I would take care of the rocking horse rocker pattern while I was at it.
The rocking horse plans call for the rockers to be cut out of a plank and then dowels inserted from underneath the rockers to strengthen the short-grain area of the rocker.
Now, I am sure that this will work ok, but I wonder if it would not be better to do a bent lamination for the rockers on the rocking horse. The short grain problem would be gone, and I think it would end up being stronger. What would you do? Second question. If I go with the bent lamination, how much would you deviate from the stated radius of the rocker to account for any springback? I am not sure I need to adjust any. If I remember correctly, the springback on a bent lamination should be little or none.
Thanks for the help here. I am trying to get this done this weekend and need to make up my mind.
-- -- Rob Hix, King George, VA
View GaryK's profile
GaryK
8541 posts in 516 days
267 days ago
I would think that a solid piece would be a lot faster and easier. It’s not like a rocking chair for a 120+ pound
adult. Almost all I have seen use a solid piece. That’s exactly what I am going to use when I build one.
If you were to laminate them the amount of spring back would depend on the thickness of your
veneers. The thinner they are the less the spring back. It’s impossible to give you a number.
View sandhill's profile
sandhill
277 posts in 452 days
267 days ago
I have glued up some backs for chairs and always had spring back of about 1/4” or more. Don’t forget the back of the rockers should extend a little and be flat to keep from tipping over backwards and causing a trip to the emergency room for stitches. Always account for CG’s
-- Just another day in paradise.
View EaglewoodsPres's profile
EaglewoodsPres
22 posts in 258 days
258 days ago
I wouldn’t think springback would be an issue on this project. You could just adjust the build to the radius. That being said, Gary is right the thinner the veneer, or slats, the less spring back. AND the tighter the radius the more the springback. I used to work at a shop that did alot (I mean alot) of radius cased openings. 6” wide, 3 ft radius, mahogany, 3/16” slats would spring approx 3/4”. It really is trial and error. But again, on your project I wouldn’t think springback would be an issue.
-- Chris ( Eaglewoods@sbcglobal.net )
View lew's profile
lew
1689 posts in 284 days
258 days ago
You could try to add some “gusset plates” on one side of each end of the rocker- where the grain is the “shortest”. If you use a contrasting 1/4” type plywood piece (birch on walnut) and shape the gussets to mimic the rocker shape it will really increase the strength and looks nice as well. If the rocker is 36” long, each gusset would be about 8” long and if the rocker is 4” wide the gusset would be about 3” wide.
View tenontim's profile (online now)
tenontim
957 posts in 273 days
255 days ago
Unless the rockers are a relatively small radius, you would probably be better off cutting the out of solid stock.
The rule on rockers is: the flatter the rocker the faster it rocks. Also, if the radius on both rockers is not the same it will rock around in a circle (you would have to have your spring back on both rockers to come out the same)
If you use an epoxy type glue, you won’t have much spring back. Titebond type glues will let the wood “creep”
-- Tim -- http://tmuli.com
View Harold's profile
Harold
294 posts in 376 days
255 days ago
How bout cutting your rockers from the plank and then laminate 1 or 2 thin strips on the runners, you could even use a contrasting wood to add alittle contrast. You would be using the runner as your form, so you wouldn’t need a jig set up or anything.
-- If knowledge is not shared, it is forgotten.
Bookmark And Share This Page
