Ulmia Bench Parts - Need Help Locating
« back to Hand Tools forum
Forum topic by JCG936 posted 10-14-2017 08:55 PM 1688 views 0 times favorited 5 replies Add to Favorites Watch
View JCG936's profile
JCG936
2 posts in 466 days
10-14-2017 08:55 PM
Topic tags/keywords: ulmia front vise replacement parts clamp question tip resource
Just joined and I am looking for advice on where to find a replacement part for Ulmia front vise. Unfortunately, while moving – the top was dropped and the front vise knuckle (?) was a casualty and therefore needs to be replaced. I do not want to buy whole vise – just a replacement part. I know I can remove the knuckle by removing the roll pin. Appreciate any and all advice on where to get, name of the part as I would love to continue using the front vise and bench.
Thanks in advance !
-- JCG Annapolis, MD
5 replies so far
View Tim's profile
Tim
3812 posts in 2203 days
#1 posted 10-16-2017 01:06 PM
Pictures might help.
View waho6o9's profile
waho6o9
8539 posts in 2818 days
#2 posted 10-16-2017 01:18 PM
We are the US distributor for Ulmia and can import workbenches for you. We do not have them in stock but can have them shipped directly from the Ulmia factory in Germany to you. The Ulmia section of their catalog can be seen here:
http://www.ulmia.de/English/Ulmia-Hobelbaenke.htm
Please contact me at chris@pecktool.com or click on the contact us link at the top of this page for more information.
http://www.pecktool.com/product-category/workbenches/
Good luck now and welcome to LumberJocks
JCG936
2 posts in 466 days
#3 posted 10-16-2017 09:34 PM
I have attached pictures of the vise and broken knuckle.
Any help will be greatly appreciated.
Thank you in advance.
/Users/johncgilbert/Desktop/Ulmia Bench Vise 2.jpg/Users/johncgilbert/Desktop/Ulmia Bench Vise 1.jpg
View BigYin's profile
BigYin
421 posts in 2657 days
#4 posted 10-16-2017 09:43 PM
punch out pin, remove wood handle then take to welder. if a steel fitting TIG weld it. if cast iron BRONZE weld it. as a high stress component it might last till you get a new one.
most machine shops can make you a new one – but expensive if you want copied.
However a simple machining ragther a copy could be quite cheap, one block of steel mounted in a lathe to drill / bore handle hole, remounted to drill / bore the shaft hole and drill press or lathe to drill the pin hole. you end up with a servicable square steel block instead of a fancier T shaped one.
-- ... Never Apologise For Being Right ...
waho6o9
#5 posted 10-16-2017 09:51 PM
Agricultural plumbing supplies
