Electrical troubleshooting Miter Saw
Forum topic by Ben posted 10-14-2017 04:30 PM 328 views 0 times favorited 3 replies Add to Favorites Watch
View Ben's profile
Ben
384 posts in 2973 days
10-14-2017 04:30 PM
I have a 10 year old Hitacho C10FSH.
Very good saw which is no longer made.
It started to run only intermittently, and the brake stopped working.
I replaced the brushes and the switch/trigger to no avail.
It’s been sitting in the corner of my shop for months. Today I went to clean it off and test if and it fired right up!
But only for about 3 cycles. Now it’s dead again.
Any ideas what the problem could be?
Trying to decide whether it’s worth putting any more money into. If it does run, there is a strange blade wobble upon startup, then it balances itself after a second.
I replaced the saw with a Makita (piece of junk in comparison) but it would be nice to have a chop saw at home when Makita is parked on a job site.
Thanks for any tips.
B
3 replies so far
View Loren's profile
10477 posts in 3764 days
#1 posted 10-14-2017 06:10 PM
I googled it and found this comment:
“This was the best tool in my shop for a while. I take special care of this saw. It now has some major problems – frequently it will not start. I have to raise and lower the blade guard and move it up and down. There must be a short in the electricl somewhere. As good as I loved it at the beginning – I would not buy another Hitachi product.”
Maybe that’s your problem.
View JCamp's profile
JCamp
795 posts in 667 days
#2 posted 10-15-2017 12:25 AM
Any chance the male end of the cord is going out? To me it sounds lik a short somewhere or a capacitor is going bad.
I had a remote control car (not the same as a saw I know) and it started only working in spurts. I took it apart and found that a ground had broken
If u aren’t afraid of ruining it a good first step would b to take it a part and check all the wire connections After that you’d probably hav to start testing all the components
-- Whatsoever thy hand findeth to do, do it with all thy might
View bigblockyeti's profile
bigblockyeti
5204 posts in 1837 days
#3 posted 10-15-2017 01:33 AM
Check the cord first after that brushes and switch are next probable (and most common) suspects. After that the condition of the commutator can be an issue as the brake on these saws powered by universal motors short the motor as a generator and are very rough on brushes and commutators. Any spade connectors can become loose over time with enough temperature cycling resulting in intermittent operation.
