Table saw link belt punched when raising blade
Forum topic by LucasWoods posted 10-14-2017 04:08 PM 464 views 0 times favorited 5 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
445 posts in 1573 days
10-14-2017 04:08 PM
So yesterday I raised my blade up all the way and went to turn my Grizzlt G1022 table saw on to do a nickel test and slight smoke started to come out of the cabinet and the arbor wouldn’t spin.
Come to find out when I raised the blade up all the way (roughly 3 1/8th depth of cut) the link belt would get pinched between the underside of the TS top and the pulley.
What can I do to resolve this? Reposition the motor a little lower on the motor support so there is a slightly higher angle?
In order for the link belt to not get pinched I have to sacrafice about a 1/4 inch of cut depth (maybe a little less)
Solutions?
-- Colorado Springs, CO - USAF
5 replies so far
View Woodknack's profile
Woodknack
12468 posts in 2620 days
#1 posted 10-14-2017 04:34 PM
The green link belts are wider than red link belts and ride higher on the pulley. So you probably need a red belt. Check width and everything before buying but that’s probably it.
LucasWoods
#2 posted 10-14-2017 04:40 PM
Thank you!
LucasWoods
#3 posted 10-14-2017 04:47 PM
Does HF carry them?
Woodknack
#4 posted 10-14-2017 05:08 PM
No. The HF is 1/2” (I think) and you probably need a 3/8” (measure your old belt if you have it). I just checked on Amazon and they have 3/8” green belts so ignore my remark about color.
LucasWoods
#5 posted 10-14-2017 05:14 PM
Ok
