auger hand drill using small bits
« back to Hand Tools forum
Forum topic by HermanKuhn posted 10-14-2017 01:25 PM 561 views 0 times favorited 6 replies Add to Favorites Watch
View HermanKuhn's profile
9 posts in 2091 days
10-14-2017 01:25 PM
So i have an auger bit hand drill that I love to use, but can only go down to 1/4 inch drill bits. Does anyone know of an adaptor that can bu used for small bits in tha auger hand drill?
View bondogaposis's profile
4634 posts in 2284 days
#1 posted 10-14-2017 02:29 PM
Never heard of one, that is why they have egg beater drills.
-- Bondo Gaposis
View BlasterStumps's profile
545 posts in 372 days
#2 posted 10-14-2017 09:03 PM
Some brace drills will grip a 1/4” hex shaft of a “mini drill chuck”.
View Mr_Pink's profile
50 posts in 304 days
#3 posted 10-15-2017 12:19 AM
Lee Valley sells a hex bit adapter, which is handy when you’re using the brace as a driver; but I’ve never used the adapter with drill bits.
View Tim's profile
3758 posts in 1894 days
#4 posted 10-15-2017 06:42 PM
Yes, there are jacobs chucks that have a square shank to go in a brace, but you’re probably better off with an egg beater or breast drill.
Also Mr. Pink’s idea is good, you can put any hex 1/4” bit adapter in many braces. You’d need to buy a set of bits with 1/4” hex shanks that way though. I suppose you can put the 1/4” shank directly in the chuck too.
View MrRon's profile
4672 posts in 3176 days
#5 posted 10-17-2017 01:15 AM
A brace is not good for very small drills. The small bits can be broken too easily because a brace is hard to keep on a spot while turning it. I don’t know how small a drill bit you want to use, but anything smaller than 1/4” is too fragile for the action of a brace. Besides, small twist drills don’t cut very well at such a slow speed. Were talking maybe 30 RPM with a brace.
View WayneC's profile
13751 posts in 4030 days
#6 posted 10-17-2017 03:10 PM
A number of higher end braces will hold round bits. Also there are smaller bits that are attached to a brace end. A third option is a drill chuck that mounts in a brace. To Address Ron’s point about speed you could use a small sweep brace (5-6” sweep) to get more speed. The small sweep braces are also good for driving fasteners.
