Redesigning Joint of chair
Forum topic by grttt3 posted 02-06-2011 07:02 PM 1021 views 0 times favorited 5 replies Add to Favorites Watch
View grttt3's profile
10 posts in 3151 days
02-06-2011 07:02 PM
Topic tags/keywords: question
Trying to find a better method of refastening a broken chair leg. Tried “Gorilla Glue” did not work.
Any suggestions?
5 replies so far
View Carl Webster's profile
Carl Webster
82 posts in 2728 days
#1 posted 02-06-2011 07:14 PM
You might try installing a larger diameter wood screw thread/threaded bolt into the leg. If that doesn’t work try an epoxy glue.
-- Carl in SC
View jmichaeldesign's profile
66 posts in 2713 days
#2 posted 02-06-2011 07:17 PM
I would use epoxy, rough up the inside of the hole, and if you have a dremel/die grinder i would try to taper the hole so that the diameter is larger at the bottom of the hole. Epoxy is great stuff, but it’s much more of a mechanical bond than a chemical bond, the surface needs to be rough and with the taper it should hold really well.
View Lee Barker's profile
Lee Barker
2170 posts in 2781 days
#3 posted 02-06-2011 10:09 PM
I’m nervous about the epoxy clogging the threads of the inserts.
If the other legs are sound, we can assume the existing system is adequate.
So, another solution would be to plug the holes and rebore them for the threaded inserts.
I’d enlarge the holes and it would be best if you could plug them not with dowels but with plugs, so the grain will give more bite to the inserts. The plugs could be epoxied in or yellow glued.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
#4 posted 02-06-2011 11:49 PM
Just put bolts in the threaded inserts when you epoxy them in place, any epoxy in the threads won’t hold onto the bolt, it will just thread right out.
View Dez's profile
1166 posts in 4007 days
#5 posted 02-07-2011 12:44 AM
I cast my vote for drilling them out oversize and gluing in plugs, re-drill to the correct size and epoxy in the inserts.
If you are worried about epoxy fouling the threads put vasoline on the bolt, thread them into the insert and then epoxy them in place.
-- Folly ever comes cloaked in opportunity!
