Need recommendations for rip blade
Forum topic by upplepop posted 10-11-2017 11:14 PM 545 views 0 times favorited 8 replies Add to Favorites Watch
View upplepop's profile
10 posts in 1080 days
10-11-2017 11:14 PM
Topic tags/keywords: table saw tablesaw rip ripping blade
Hi all. I’m looking for recommendations for a rip blade for my table saw. I don’t have much experience with anything other than combination blades, and am getting confused about what would be best for my needs.
I need a rip blade that can do extremely smooth, glue-ready cuts to minimize the amount of cleanup I have to do after ripping. I have a SawStop contractor saw (120V, 1.75HP, 10” blades). About 90% of my cutting will be on 4/4 material, and probably not doing anything over 6/4. I will be using it on relatively hard woods like padauk, wenge, and purpleheart.
My biggest points of confusion are if a 24-tooth blade will be able to give me the cut I need or should I go up to 30… and if I go with a thin kerf given the power of my table saw, do I need to be concerned about deflection?
A flat-top grind would be a nice bonus, since I could one of those, but I’m not willing to sacrifice the rip quality if another grind (triple chip?) would provide a smoother cut.
Specific brand & model recommendations would be much appreciated. I am willing to pay a premium for a nice long-life blade.
Thanks in advance!
8 replies so far
View Loren's profile
10114 posts in 3584 days
#1 posted 10-12-2017 12:10 AM
You won’t go too far wrong with a Forrest blade.
Forrest recommends stabilizers with thin kerf
View pintodeluxe's profile
5596 posts in 2749 days
#2 posted 10-12-2017 12:12 AM
I have been using Freud LU86 thin kerf general purpose 40 tooth blade for almost everything lately. It rips and crosscuts hardwoods well.
I used to make rip cuts with a 24 tooth dedicated ripping blade. The cuts were not the cleanest, and crosscuts were poor quality so I switched to the 40 tooth blade. It works great for me, but I’m not cutting wenge either.
View TheFridge's profile
9112 posts in 1422 days
#3 posted 10-12-2017 12:23 AM
I use a Forrest ww2 for rip and xcut. Works great for me.
View Ripper70's profile (online now)
903 posts in 845 days
#4 posted 10-12-2017 12:59 AM
Read this by resident blade guru knotscott.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View d38's profile
66 posts in 198 days
#5 posted 10-12-2017 02:17 AM
I’ve been doing a lot of internet searching/surfing lately for table saw blades. I’ll be cutting oak, and don’t mind a jointer pass, so not quite the same as your needs.
I purchased an Infinity 2 blade set (24 tooth FTG rip, and 50 tooth ATBR combo).
I went with full kerf for blade stiffness—but lots of people say thin works great too.
The 40 tooth Infinity Super General is reported to give very smooth rips and cross cuts. It has 30 degree High ATB teeth. Forrest WWII 48 tooth and Freud P410 have same HATB teeth. Won’t rip as fast as a 20 tooth FTG, but smoother, which you’ve listed as a priority.
View Madmark2's profile
379 posts in 524 days
#6 posted 10-12-2017 02:31 AM
Freud LU83R010 combo is what I use and get real clean glue ready cuts. The Freud blades have the sides of the teeth double ground for clean cutting. Their rip only blades are very good too.
View coxhaus's profile
79 posts in 830 days
#7 posted 10-12-2017 04:45 AM
I use a Freud Industrial 24T rip blade full kef for ripping which is a low cost table saw blade. I use a Freud Industrial Cabinet makers 60T cross cut full kerf blade for cross cutting and plywood. I just switch blades back and forth as it can be done in a couple of minutes on my old Unisaw 3hp. But I am no expert just a hobbyist.
View Woodknack's profile
11317 posts in 2316 days
#8 posted 10-12-2017 05:37 AM
