Need help with any easy finish for wood earrings
Forum topic by kindogg posted 10-11-2017 07:19 PM 570 views 0 times favorited 13 replies Add to Favorites Watch
View kindogg's profile
kindogg
3 posts in 255 days
10-11-2017 07:19 PM
Hey guys! I recently started making wooden jewelry and I’ve been try to find a finish that is easy to apply to small pieces. So far I’ve tried danish oil, formby’s tung oil, spray shellac, spray poly and straight past wax. I haven’t been very happy with any of these.
I’m looking for something that has at least some shine/gloss to it but is easy to apply to ten or so small pieces at a time. I’m hoping to sell some of these things eventually so time and effort are a concern.
My next step is probably to try a buffing setup but I wanted to ask for some advice first. Thanks for any help in advance! Here are a few I’ve made so far.
13 replies so far
kindogg
3 posts in 255 days
#1 posted 10-11-2017 07:26 PM
View Loren's profile
10476 posts in 3675 days
#2 posted 10-11-2017 07:40 PM
You may want to dry dipping them in boiled
linseed oil. You may not love the effect
but customers probably will. BLO is cheap
and dipping is easy.
View Aj2's profile
Aj2
1441 posts in 1825 days
#3 posted 10-11-2017 07:55 PM
Loren suggestion is good. My thoughts were spraying with a rattle can of Laquer. It comes in satin,semi gloss and gloss.Deft is a good one.
Good luck with your craft.
-- Aj
View Jack Lewis's profile
Jack Lewis
276 posts in 1106 days
#4 posted 10-11-2017 07:56 PM
Rattle can lacquer is always a possibility when gloss is desired.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
View MrsN's profile
MrsN
986 posts in 3553 days
#5 posted 10-11-2017 08:00 PM
First, beautiful pieces.
I have made a few jewelry pieces, mostly finished with a rattle can of lacquer. Put a piece of tape sticky side up and set the little pieces on in, then spray.
It may take a couple of coats. when you have the different woods they absorb the finish a bit differently so a few coats are needed to build up a uniform finish.
View onoitsmatt's profile
onoitsmatt
392 posts in 1203 days
#6 posted 10-11-2017 08:07 PM
I have made a few pieces and rubbed them with BLO. Poked some stiff wire into the side of a box and hang them to dry.
-- Matt - Phoenix, AZ
View Andybb's profile
Andybb
1031 posts in 631 days
#7 posted 10-11-2017 08:14 PM
-- Andy - Seattle USA
View oldwood's profile
oldwood
137 posts in 1271 days
#8 posted 10-12-2017 02:40 AM
I find that a seal coat (or two) of rattle can shellac before the lacquer works best for a uniform finish. Nice work.
View jonah's profile
jonah
1727 posts in 3326 days
#9 posted 10-12-2017 03:41 AM
Rattle can gloss lacquer if you want shine, dip in BLO if you don’t.
kindogg
3 posts in 255 days
#10 posted 10-12-2017 08:07 PM
Thanks everyone!
I’m gonna try dipping in BLO and see what I get. Should I worry about wiping excess BLO off, or drips (on the piece) while hanging to dry?
#11 posted 10-12-2017 08:16 PM
I think it will all soak in or drip off. Try
something like hanging the dipped pieces
on a line over a pan for 30 minutes and
then wiping off any excess. After a few
days it should be clear if the pieces need
another dip.
You could also try a long soak for several
hours.
View Thomasdrengen's profile
Thomasdrengen
1 post in 254 days
#12 posted 10-12-2017 08:24 PM
I’v had good experience with Rattle can gloss lacquer as mentioned. It gives a good shine.
Good luck with it.
View Woodknack's profile
Woodknack
11813 posts in 2407 days
#13 posted 10-12-2017 08:43 PM
You could try dipping in wb poly or shellac but you run the risk of a drip but it’s probably the surest way to get a high gloss with low effort.
