drilling straight hole
Forum topic by Karda posted 10-11-2017 04:05 AM 817 views 0 times favorited 7 replies Add to Favorites Watch
View Karda's profile
Karda
1222 posts in 668 days
10-11-2017 04:05 AM
Hi, i want to make this tool rest thigs are fine until drilling the cross hole, the bottom is way off from the top. I am doing this on a drill press with a drill press vice. How do I get the piece plumb withe the drill bit so the hole is straight thanks. here is a pic of the rest
7 replies so far
View Loren's profile
10477 posts in 3762 days
#1 posted 10-11-2017 04:09 AM
Drills wander, unfortunately.
A more reliable approach for jigs is to cut
a dado and fill the slot, leaving room for
the rod to pass through.
Karda
#2 posted 10-11-2017 05:37 AM
thanks, I forgot about the dado, I did that it will work
View Gilley23's profile
Gilley23
489 posts in 496 days
#3 posted 10-11-2017 09:30 AM
I’m confused as to exactly where you’re trying to drill?
Karda
#4 posted 10-11-2017 03:26 PM
a hole through wood from one end to another with a drill press that is why I added the picture
View Woodknack's profile
Woodknack
12329 posts in 2494 days
#5 posted 10-11-2017 03:47 PM
A lazier approach is to drill halfway or so from each side. The inside middle may not be perfect but no one will ever see it, as long as the holes align you’re good.
woodbutcherbynight
5545 posts in 2523 days
#6 posted 10-11-2017 04:52 PM
- Loren
+1 have used this method many times.
Karda
#7 posted 10-11-2017 06:15 PM
i’m not worried about it be seen but the hole needs to be reasonably straight
