Jugs for small parts
Forum topic by Kimmiecs posted 10-11-2017 02:51 AM 920 views 0 times favorited 15 replies Add to Favorites Watch
View Kimmiecs's profile
Kimmiecs
1 post in 257 days
10-11-2017 02:51 AM
I’m a newbie woodworker. I’m trying to build a toy ship ! How do I cut small pieces safely that are -1/2-1/2-1? I’m trying to cut them on a bandsaw but I’m afraid there’s a much safer way to do it. Any ideas? Thanks for all your help!!!!! Kimmiecs
15 replies so far
View Loren's profile
10476 posts in 3677 days
#1 posted 10-11-2017 03:02 AM
http://www.leevalley.com/us/wood/page.aspx?p=41780&cat=1,43000
The jig can cut miters and tapers but it does
very well gripping small parts for cutting with
a table saw or band saw with a little ingenuity.
A fence for the band saw helps.
You can also use the eraser end of pencils
to hold and guide small parts on a band saw.
View jonah's profile
jonah
1727 posts in 3327 days
#2 posted 10-11-2017 03:26 AM
Band saws are pretty safe as a rule, especially compared to table saws. Use a sacrificial push stick or two made from some scrap plywood to hold and push the piece through the blade.
View Lazyman's profile
Lazyman
2064 posts in 1416 days
#3 posted 10-11-2017 03:51 AM
You can make a simple sled for cutting small parts such as this one:
https://www.woodsmithplans.com/plan/multipurpose-small-parts-sled/
Doesn’t have to be this elaborate. A sled generally makes cutting small pieces more secure and therefore safer. And if your bandsaw has a miter slot you can make one for that as well.
Of course you can always cut them by hand but a miter box like this can help:
https://www.woodsmithplans.com/plan/pull-saw-miter-box/
View AlaskaGuy's profile (online now)
AlaskaGuy
4218 posts in 2338 days
#4 posted 10-11-2017 03:55 AM
- jonah
Band saws are pretty safe as a rule, until you stick you finger in the blade.
View Kelly's profile
Kelly
2039 posts in 2973 days
#5 posted 10-11-2017 06:22 AM
I use these to cut small parts: http://lumberjocks.com/projects/105726#comment-4162090
For items that need a little more holding power, I use these: http://lumberjocks.com/projects/301810
View Woodknack's profile (online now)
Woodknack
11828 posts in 2409 days
#6 posted 10-11-2017 06:48 AM
- AlaskaGuy
Gross. I checked the OSHA website, 12 amputations this year for bandsaws, 13 for tablesaws.
Woodknack
#7 posted 10-11-2017 06:51 AM
- Kimmiecs
I would cut 1/2×1/2 long strips on the tablesaw then cut those into 1” pieces using the bandsaw or tablesaw w/ sled. If you only have a bandsaw, you can make a notched push stick.
jonah
#8 posted 10-11-2017 10:41 AM
- AlaskaGuy
- Rick_M
Band saws are used under appallingly dangerous conditions in slaughterhouses, so I’m betting that skews the stats.
View Redoak49's profile
Redoak49
3289 posts in 2017 days
#9 posted 10-11-2017 11:05 AM
Yes, and it is only OSHA reported and does not include home accidents.
No doubt both tools can ruin your day.
View BHZ's profile
BHZ
8 posts in 1007 days
#10 posted 10-11-2017 12:18 PM
Scroll saw might be a better tool for small parts as well.
View GR8HUNTER's profile
GR8HUNTER
4007 posts in 741 days
#11 posted 10-11-2017 01:24 PM
table saw …push block …small miter box …for length …with handsaw
View RandyinFlorida's profile
RandyinFlorida
252 posts in 2096 days
#12 posted 10-11-2017 02:08 PM
a hand saw and miter box? With a good quality sharp saw you could cut through most woods of that size in just a few strokes
-- Randy in Crestview Florida, Wood Rocks!
Woodknack
#13 posted 10-11-2017 02:54 PM
- AlaskaGuy
- Rick_M
Band saws are used under appallingly dangerous conditions in slaughterhouses, so I m betting that skews the stats.
- jonah
Doesn’t matter if it’s used on wood, metal, meat, or something else, it’s still a bandsaw. Also the table saws are not all used on wood either.
jonah
#14 posted 10-12-2017 03:51 AM
Oh please. There’s a band saw in the back of every grocery store. Table saws are relatively rarely used for non wood applications, and most of that is cutting plastic.
Kelly
#15 posted 10-12-2017 03:59 AM
Oh please, nearly every metal shop dealing in aluminum stock has a table saw dedicated to cutting it.
Couldn’t resist, since the two metal fabrication shops I had cut stock used Unisaws to make single cut runs.
Oh please. There s a band saw in the back of every grocery store. Table saws are relatively rarely used for non wood applications, and most of that is cutting plastic.
- jonah
