Working with brass
Forum topic by RMP posted 865 days ago 1131 views 0 times favorited 4 replies Add to Favorites Watch
View RMP's profile
RMP
50 posts in 1341 days
865 days ago
Hey LJs , I have a question about cutting brass. I know it can cut fairly easy on a table saw, but I have had a project rolling around in my head for a while that requires a rabbit cut into a piece of 3/8” thick brass , round, about 2” dia. What I’m wondering is if i can cut it with a router bit without destroying the bit. They’re not cheap as you all know and I don’t have many. If any of you guys have any thoughts on this I would greatly appreciate it. Best thoughts. RMP…....
View horologist's profile
horologist
79 posts in 1936 days
#1 posted 865 days ago
With the right blade you can cut brass nicely on a bandsaw. For small pieces it is hard to beat a piercing saw and a bench block. I would never recommend a tablesaw. Similarly I know of people experimenting with routers to cut out brass clock plates, I’m not convinced this is a good idea.
If you only have a small quantity of brass to cut I would recommend farming the task out to a local machine shop, much cheaper than hospital bills and replacing damaged tools. If you are going to be cutting a lot of metal then perhaps it is time to invest in a small mill, a Sherline would be worth investigating.
-- Troy in Melrose, Florida
TopamaxSurvivor
13179 posts in 1872 days
#2 posted 864 days ago
I would farm it out or use a file and hack saw.
-- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence
View Viktor's profile (online now)
Viktor
440 posts in 1615 days
#3 posted 864 days ago
1. Secure the piece.
2. Use lowest RPM and small diameter bit. At 12000RPM and 5 mm diameter you get about 3m/sec linear cutting speed. It is still too high for non-ferrous metals but OK.
3. Use small increments (1 mm or less).
4. Use guide, don’t rout free hand.
5. Cool and lubricate with oil.
6. If doing larger amount of cutting invest in specialty bit. Wood bits angle is to sharp for metal and cause grabbing, that’s why #1, 2, 3, and 4 are important.
View Dan Lyke's profile
Dan Lyke
1372 posts in 2321 days
#4 posted 863 days ago
I’d find someone who has a milling machine, and do it that way. My mill runs way way slower than my router, and the bit is open and accessible to add water and to watch the waste material’s color to see when it’s getting too hot.
Unfortunately, you’re on the other side of the country from me.
