| Forum topic by mjlauro | posted 1909 days ago | 4321 views | 0 times favorited | 21 replies | ![]() |
1909 days ago |
Topic tags/keywords: question tablesaw I am about to upgrade to a cabinet style table saw. I have always used a contractor model so I got used to the sawdust just piling up under it. If I do decide to buy a cabinet saw do I have to buy a dust collection system? Any input is really appreciated, and quickly too, because I have to make a decision as to whether or not to buy the saw. In case anyone is curious I got a guy who can get me a delta hybrid with the biesmeyer fence and upgraded mitre gauge, for under a grand. But like I said I have to act quickly. Oh, one more thing do I need more than 1 3/4 hp as a hobbyist? Grizzly has some 3hp cabinet saws in the $1000 neighborhood also. Any input? |
21 replies so far
#1 posted 1909 days ago |
Well, you don’t have to have DC on anything. It just makes things cleaner. As to which saw or how much HP you need really depends on what you are doing. If you find that your -- Gary - Never pass up the opportunity to make a mistake look like you planned it that way - Tyler, TX |
#2 posted 1909 days ago |
Did Tim the Tool Man ever go with anything but the biggest-baddest-tools. A V8 powered drill press would be his choice. Really it all becomes your choice. Power is good when you need it. While working at the toy workshop 2 weeks ago. We were cutting 1.5” thick slices from some Oak. (Resawing) we had to do about 20 boards and wait for 20 minutes because we kept overheating the saw. And we were cutting 120 boards that way. It took a while. So not having enough power can cause you to delay what you are doing. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#3 posted 1909 days ago |
Buy all the power and iron you can handle. I’m using a Powermatic 66 I picked up three years ago. The guy I got it from gave me a dust sucker to go with it but I gave it away. My setup is on wheels and I move the machines outside most of the time. That way the dust stays outside for the most part. The machine has a 4” hookup at the base but I just reach in through the access panel on the front and scoop it out if it gets too deep. So no, you might not need one but if you confine yourself to the indoors for your sawing a dust collector can help save your lungs and sinuses. Also, you might want to add one of those hang from the ceiling type air filters that snags the finest and most harmful particles out the shop air. Hope some of this helps. always, -- "Imagination is more important than knowledge" -- Albert Einstein |
#4 posted 1909 days ago |
I personally would go with the Grizzly 3hp and use my shop vac on it until I could afford a real dust collector. That’s was I did and have never been sorry I did. -- DaveH - Boise, Idaho - “How hard can it be? It's only wood!” |
#5 posted 1909 days ago |
You can’t fix lungs that get messed up—I would go with a dust collector. -- Those that say it can't be done should not interrupt those who are doing it. |
#6 posted 1909 days ago |
With a 3hp cabinet saw you will need to have 220 V power in the shop, the hybrid you can run on 110 V or 220 V. Personally I think the Grizzly cabinet saw is a better deal and is the way to go. I would recomend a dust collector with low micron bags or canister filter for any of the machines you mentioned, includeing the Contractors table saw. A air filtration machine and a good dust mask should be in order also. AOS safety makes a good particle mask for about $15. Fine dust is nothing to fool around with. |
#7 posted 1909 days ago |
I wear a mask whenever I run any tools because I don’t have any real dust collection. My jet cabinet saw is the absolute least dusty tool in my shop. I would say that if your contractor saw piled up dust underneath, the cabinet saw will do the same but it will be contained in the cabinet. The real benefit to the cabinet saw is the size, power and stability factor. There is no added requirement for dust collection with the cabinet saw (IMO). If I had to rank my shop tools I would do it like this (most dusty to least dusty). 1. Jet Band saw – that thing throws dust that floates in the air. It is also closest to the door of my shop for that very reason. BTW, I use my band saw for dimensional ripping more than my table saw (it scares me). I usually finish the dimensioning with my planer. 2. Router table – depending on what I am doing and how sharp the bit is, it can throw dust but more shavings than dust. Problem is they are not contained and fly around some. 3. Planer. If it is throwing up dust the blades are not sharp and/or I am prolly taking too deep of a cut. Curly wood should be flying out not dust. I do wear a mask though. 4. Jointer. Not much dust just lots of curly shavings that pour out of the chute. 5. RAS – flys out the back into a chute. not much dust, just saw chips. 6. Jet Cabinet saw – The table saw does not make a lot of dust. Because of the way the blade spins, the chips go down into the cabinet. I sweep them out after a big run. Dust collection is a great thing. I plan to add it to my shop in the near future, but the purchase of a cabinet saw does not make it any more important than it was before the purchase. -- Scott - Chico California http://chicowoodnut.home.comcast.net |
#8 posted 1909 days ago |
I purchased the Delta 36-717 that you are considering last year from Amazon.com. I paid $696 total. The truck driver wheeled it right into my shop on a pallet jack. The driver asked me if they had a sale or something. He had to deliver 5 of them that week in the Dallas area. It seems that the last weekend of every month they have a tool sale. They don’t advertise it, you just have to keep checking the price on what you are looking for. I watched this for about 6 months. It hovered between $799 and $1199 and went up and down like a yoyo. On April 30 it dropped to $597 (one day only) with $99 shipping and I jumped on it. I purchase a lot of my power tools from them. I have never had a problem. It has plenty of power. Use a heavy cord, a sharp blade and make sure your fence is aligned with the blade. It passed the nickel test out of the crate. Dust collection helps but you can also just vacuum out the inside of the cabinet. I agree with Scott, unless you are cutting dadoes or using it to make cove molding, you don’t get a lot of dust in the air. I have a powerful DC but have to admit that I don’t lways turn it on just to make a couple of cuts on the saw. But then again I also have a power air filtration system that is usually running when I’m in the shop. I just bought the new Kreg Router table (floor model) from them. Everyone sells it for $499. I purchased it for $449 (no tax or shipping was another bonus) and received the locking casters, feather boards, and a couple other things for free. But again, the price changes every couple of days. -- NorthWoodsMan |
#9 posted 1909 days ago |
I have a 1.5 hp contractor Jet tablesaw. If I had the money to spend over again, I definitely would buy a 3 hp cabinet saw. I’ve never overheated the motor yet (that I know!), but it does bog down a little sometimes when ripping 6/4 hardwood. -- Robb |
#10 posted 1909 days ago |
i have the grizz 3hp left tilt. A truly great saw. I use my shop vac for now but am installing a dust collector. The shop vac works fine for now. Once every few months I do a manual clean up. -- making sawdust.... |
#11 posted 1909 days ago |
I’ve got a Grizzly 1023 right tilt saw with the slider attachment and after using a Crapsman for years, this Grizzly saw is a great piece of machinery. There must be something right about the Grizzly saws because there are thousands of them being sold. -- Jim |
#12 posted 1909 days ago |
I have a 3 horse Jet cabinet saw. I wish it was a 14” 7 1/2 horse. My dust collection doesn’t work well on this saw(too small). I just vac it out every once in awhile. A zero clearance insert helps to keep out everything except sawdust. -- Thos. Angle, Jordan Valley, Oregon |
#13 posted 1909 days ago |
Dust collection is like hearing protection, if you don’t use it for “making just a couple of cuts” then what’s the point of having it at all? I use both always. Just my two cents. If you end up using your shop vac you might be interested in an automagic switch that sears sells: http://www.sears.com/shc/s/p_10153_12605_00924031000P?keyword=craftsman+switch Works with any 120v system. Plug tool into one outlet, vac into the other and the switch on the tool starts the vac as well and runs it for a couple of seconds after the tool is switched off to clear the hose. I’ve not had a problem with this set up popping breakers with a Jet dust collector and a dewalt hybrid saw or a rigid contractor saw. Have also used same set up with big shop vacs and Bosch and Makita protables. And some of the better shop vacs have a tool actuated switch built in but they cost as much as a good dust collector and lack capacity so you end up emptying a lot. On the plus side, they’re really portable. |
#14 posted 1908 days ago |
I would recommend it. Why? Because I don’t have it. Everything in the shop, including me, gets covered by the latest flavor. At least a shop vac, but I am the kind that would decide to go whole-hog if I had the budget. |
#15 posted 1908 days ago |
If you’re serious about woodworking, you’ll never be disappointed if you buy a 3hp table saw. Sounds like budget is an issue. If so, I’d highly recommend the Grizzly 3hp models for just under $1000. My son-in-law bought one, and I’ve used it. It compared favorably with my current 3hp Delta Unisaw and was less than half the price. -- Gerry |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15783 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
