Router Circle Cutting Jig
Forum topic by EdsCustomWoodCrafts posted 10-10-2017 02:22 AM 1223 views 0 times favorited 11 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
775 posts in 1337 days
10-10-2017 02:22 AM
Hi Guys,
I need to pick your brains I want to be able to cut circles using my router and I’m in the process of design a jig and I’m wondering what router should I use
1.Palm ( nice size router)
2.Plunge ( control depth of cut making several passes easier )
One other question I want a jig that can accommodate multiple radiuses and plan on creating a jig with 1” increments but where do I measure from .. I’m thinking the middle centerpoint of the base and marking from there
Thanks
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
11 replies so far
View Rich's profile
Rich
2803 posts in 584 days
#1 posted 10-10-2017 04:11 AM
A bushing works well for this. No need to mount the router to the jig, just drill a hole the same diameter as the bushing and the router will drop in. You should taper the jig so that the part the router sits in is as big as the base for stability.
I’d probably go with a 3/8” OD bushing and a 1/4” straight bit. The offset will be 1/16” so drill your hole for the bushing to account for that.
-- No matter how much you push the envelope, it'll still be stationery.
MrUnix
6700 posts in 2193 days
#2 posted 10-10-2017 04:27 AM
For $10 – this thing works great… and not just for circles.
Black & Decker 76-234 Deluxe Router Guide USA
View Andybb's profile
Andybb
964 posts in 598 days
#3 posted 10-10-2017 05:09 AM
I am a huge DIY jig and tool maker and enjoy crafting them but after making band saw, table saw and router jigs for circles I spent $35 on this Jasper jig.
video
It does 1/16th” increments from 2-1/4 to 18-3/16-inches in diameter and it will even do inlays of the circles it cuts which is really cool and it’s effortless and deadly accurate. Comes with everything you need.
stand with
I understand if you want to build it yourself too. That’s always fun. There are too many to count on youtube but none I could find that were as accurate as the Jasper. Use the pre drilled holes for your brand router base, stick the pin in the right hole and cut.
Took a run at making this bookmatched guitar stand base shaped like a guitar. Took 15 minutes to cut the hole then cut the walnut insert and tap it in. I don’t work for Jasper but I love the tool.
-- Andy - Seattle USA
View Rich's profile
Rich
#4 posted 10-10-2017 05:29 AM
When someone mentions a circle cutting jig using a router, obviously different people get different visions popping into their head.
The image that popped into my head was something similar to this one, only using a bushing rather than mounting the router to the jig.
Any of these will work. Some better than others. If you want something ready-made to be able to cut just about any diameter, go with Andy’s suggestion. If you want something that will help with circles as well as to use as an edge guide for mortises, etc, go with Brad’s suggestion. If you want to make it yourself, I gave some ideas, but there are countless other concepts that would work as well, or maybe better.
EdsCustomWoodCrafts
#5 posted 10-10-2017 04:02 PM
Well I took the path of least resistance and made my own using a variance some ideas I saw on the net
I used 3/4” plywood
I didn’t use the the routers sub base to attach the jig I just screwed up into the router for underneath
The only thing that is bothering me is that my radius is off by less than 1/8” and I think it’s because I just used a nail as the pivot pin.. I think I need to use something a little more substantial almost like a pin I use in my shelf pin jig .. that way there will be no play in the pivot and thus removing the 1/8”
Thanks everyone for there in put
View Lazyman's profile
Lazyman
1937 posts in 1382 days
#6 posted 10-11-2017 03:12 AM
You didn’t mention which size bit you are using. If you used a 1/4” straight bit for example, the 1/8” error may be caused by measuring from the center of the bit rather than the cutting edge of the bit when you laid out the 1” increments for the guide pin holes. When I have needed to do this (see my 2 mirror projects), I always just use a scrap of 1/4 or 1/2” plywood, mount the router to it with the bit I am going to use and then measure the radius I want from the edge of the bit and drill a hole that is slightly smaller than than the nail I will use as the center pin to make sure there is no play. BTW with this approach, you can cut any diameter, not just even ones.
Note: if you are cutting a hole you measure from the far side of the bit. If cutting a disk, you measure from the near side of the bit.
EdsCustomWoodCrafts
#7 posted 10-11-2017 03:20 AM
You didn t mention which size bit you are using. If you used a 1/4” straight bit for example, the 1/8” error may be caused by measuring from the center of the bit rather than the cutting edge of the bit when you laid out the 1” increments for the guide pin holes. When I have needed to do this (see my 2 mirror projects), I always just use a scrap of 1/4 or 1/2” plywood, mount the router to it with the bit I am going to use and then measure the radius I want from the edge of the bit and drill a hole that is slightly smaller than than the nail I will use as the center pin to make sure there is no play. BTW with this approach, you can cut any diameter, not just even ones.
- Lazyman
I used a 1/4” spiral bit
View Sylvain's profile
Sylvain
706 posts in 2494 days
#8 posted 10-11-2017 10:52 AM
For small circles (and without a center hole), this is one solution
translation
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View GR8HUNTER's profile
GR8HUNTER
3811 posts in 707 days
#9 posted 10-11-2017 01:37 PM
would a band saw work for you ???? :<))
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
EdsCustomWoodCrafts
#10 posted 10-11-2017 01:49 PM
- GR8HUNTER
Nope my bandsaw is a piece of crap anyway the jig I made for the router fits my needs
woodbutcherbynight
4515 posts in 2403 days
#11 posted 10-11-2017 04:18 PM
Which router to use is always a tough question. For smaller sized work the palm sized ones are great because they are small and lightweight. On the other hand the larger routers obviously have more power and can take larger bits. My question would be what type of work do you generally want to use this for? Smaller work = palm router. Larger work larger router.
I use more of a tiered approach to this. For just a basic circle up to 27” I have the bandsaw jig. http://lumberjocks.com/projects/299322 This is pretty accurate through the range of the jig and gives a nice smooth edge. If I want a rounded edge I take it to the router table after making the circle and finish it off. For a more exact perfect dimension I would finish it off on the lathe. If this is something in the field then I have a ready made circle cutting jig that I made to fit both the palm and larger router.
True this takes more steps but I have the time and the jigs are made so easy to set up and use. With the broad range of projects I do a one sized fits all approach was limiting.
Something to consider for everyone no matter what the jig you make may be. While building it keep in mind it needs a home. Whether it be a hook on the wall or a box incorporate this into your design. It doesn’t do any good to make one and then jam it into a corner somewhere and it gets damaged or forgotten when needed the most.
