mitered box glue up
Forum topic by GoPhillies posted 02-05-2011 06:33 PM 3788 views 1 time favorited 10 replies Add to Favorites Watch
View GoPhillies's profile
GoPhillies
45 posts in 2865 days
02-05-2011 06:33 PM
Topic tags/keywords: question tip
I always have trouble with glue ups on larger boxs with mitered corners. On small boxes, I use large rubber bands and they generally do a good job keeping the corners tight. On larger boxes, the rubber bands don not fit around the box. Just wondering what techniques others use to get tight corner miter joints???
10 replies so far
View bigike's profile
bigike
4055 posts in 3485 days
#1 posted 02-05-2011 06:55 PM
I use a band clamp from pony and one from rockler, there’s also one from bessey. Another thing you can try is glueing two sides together and then glueing those two right angles together. You can also glue 45 degree blocks to a flat piece of stock make two or four of them and then you can clamp one to each side of the box this gives you 90 degree angle to put a regular clamp on to hold the box together. I’ll attach some pics as I find them. http://www.rockler.com/c/band-clamps.cfm http://www.sentex.net/~mwandel/workshop/miter.html
The first pic shows what i was talking about when I said to glu the two block cut at 45 deg. to get a 90 deg. Their doing a picture frame though. You also have a choice to use four or eight of these clamps, http://www.tools-plus.com/jet-58404.html
View Gator's profile
Gator
383 posts in 3873 days
#2 posted 02-05-2011 07:30 PM
I use a combination of two styles of clamps. I use the square 90 degree brackets and clamps from rockler.. they have two different sizes, and I find they work well to hold the joints square, then I wrap the band clamp around to keep them tight. Seems to work well for me.
http://www.rocklerpro.com/product.cfm?page=11318&filter=corner%20clamps
Gator
-- Master designer of precision sawdust and one of a kind slivers.
View Chris Wright's profile
Chris Wright
540 posts in 3678 days
#3 posted 02-05-2011 08:05 PM
I’ve used webbing clamps, like the Pony that bigike mentions with much success, but I’ve found that these Merle clamps are great.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/merle_clamp.html
-- "At its best, life is completely unpredictable." - Christopher Walken
View majeagle1's profile
majeagle1
1426 posts in 3693 days
#4 posted 02-05-2011 08:53 PM
I second what Chris said…... the Merle clamps are fantastic. I use them for all my boxes, although I do use rubber bands / tape on my smaller keepsake boxes and such. Anything larger, it’s the Merle clamps for me !
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
16280 posts in 4415 days
#5 posted 02-05-2011 10:10 PM
I generally use a strap clamp or two depending on the box size. I tighten the clamp(s) partially, realign the sides as necessary, then finish tightening. Sometimes if the sides are not perfectly flat, I’ll add a bar clamp or two as needed to close any gaps.
GoPhillies
#6 posted 02-05-2011 11:29 PM
Thanks for the help and suggestions, might have to order the Merle clamps.
View Jim Finn's profile
Jim Finn
2686 posts in 3119 days
#7 posted 02-06-2011 12:31 AM
I use quick clamps…....... To keep the edges from slipping apart I use pin nails.
-- No PHD just a DD214 Website> craftingcouple.com
View TheDane's profile
TheDane
5545 posts in 3860 days
#8 posted 02-06-2011 02:59 AM
The Merle Band Clamps do a good job … but I hate them!
The spring in the rewind can be a real finger mangler!
—Gerry
View DHaden's profile
DHaden
77 posts in 2855 days
#9 posted 02-15-2011 07:05 PM
I got this from Lee Valley (VeritasĀ® 4-Way Speed Clamp) and they work GREAT! I am going to buy a second set for taller projects.
-- Measure once, cut twice.
View MattinCincy's profile
MattinCincy
128 posts in 3350 days
#10 posted 02-16-2011 03:47 AM
I agree with the Dane….the rewind box has gotten me on more than one occasion. I also find it a bit unwieldy at times, and can easily scratch or mar my work. I use packing tape for a lot of box glue ups, and it works really well. I wouldn’t use it on a toybox mind you, but anything up to shoe box size is ok.
-- Wag more, bark less.
