Try Again or Trash It?
Forum topic by JSMorgan posted 10-09-2017 03:49 PM 1003 views 0 times favorited 30 replies Add to Favorites Watch
View JSMorgan's profile
JSMorgan
35 posts in 516 days
10-09-2017 03:49 PM
Topic tags/keywords: finish
Good Morning! I am at my wits end on finishing the table legs and aprons. Let me start from the beginning: 1. I sanded everything to 180. 2. I applied 2 coats of General Finishes Dye. 3. I then applied 2 coats of GF Black Stain. 4.
I then applied a coat of Shellac. 5. I then applied 2 coats of GF Gel Stain. Sanding all between coats. From the time I put on the shellac I keep getting these “dull” spots and “stripes” on the wood. Hence the reason for the gel stain. Nothing seems to work. I’ll try and post 2 photos.
30 replies so far
View Loren's profile
10477 posts in 3887 days
#1 posted 10-09-2017 03:58 PM
Insufficient build of shellac would be my
suspicion. It takes more than one coat
of shellac to seal a stained surface and
build a consistent surface film.
JSMorgan
#2 posted 10-09-2017 04:08 PM
Loren: I plan on re-sanding and try one more time. I just don’t get why this is going on. It looks like there may have been air bubbles and once scuffed, it shows the same dull spots and doesn’t take a finish or a seal coat.
View Rich's profile
Rich
4009 posts in 828 days
#3 posted 10-09-2017 04:49 PM
To add to Loren’s comment, use a 2 lb cut of shellac. Bulls Eye Seal Coat is a 2 lb cut and will build much faster than lighter cuts. You’ll still need multiple coats though.
View TheFridge's profile
TheFridge
10817 posts in 1725 days
#4 posted 10-09-2017 04:50 PM
Could be the grain rising and diving. Hard to say.
I second Loren.
View AandCstyle's profile
AandCstyle
3185 posts in 2496 days
#5 posted 10-09-2017 09:38 PM
JS, have you tried rubbing out the finish with progressively higher grits until you reach your desired sheen?
-- Art
JSMorgan
#6 posted 10-10-2017 03:16 PM
A&C: That’s the problem. It does not rub out. Any spot only gets bigger when you try to sand it. I did apply a coat of shellac (on a small place) as suggested above and it did improve some. I plan on adding a full coat of shellac and then wait a few days and try the gel stain again. Thanks for your help.
View ArtMann's profile
ArtMann
1218 posts in 1055 days
#7 posted 10-10-2017 03:51 PM
I am just curious about the complex finishing schedule. That is a lot of different products and all of them need to 100% dried or cured before moving to the next step. That would require weeks.
JSMorgan
#8 posted 10-10-2017 04:01 PM
Art: It has been weeks with several days between each coat, along with scuff sanding.
View Aj2's profile
Aj2
1952 posts in 2037 days
#9 posted 10-10-2017 04:11 PM
Black is the hardest finish to get right. Even a flat or satin look is difficult. Dont beat yourself up its not just you. :(
-- Aj
JSMorgan
#10 posted 10-10-2017 04:22 PM
AJ: Thanks, I am earning that! I did a hutch and cabinet out of the same wood and steps and it turned out okay. Not great but seeing as this is my first project, not too bad.
View Rich's profile
Rich
#11 posted 10-10-2017 04:40 PM
- Aj2
That’s true for automobile paint jobs, but dye problems on wood have to do with color consistency and accuracy. And yes, they say black is a tough one to get even color on.
Maybe I’m misreading the OP, but it sounds like he’s having problems getting a smooth surface. That would be an issue with wood prep, top coat application or even contaminates since it’s not affecting the entire surface.
Am I wrong about that, JSMorgan? Is it the color or the quality of the surface?
View CharlesNeil's profile
CharlesNeil
2469 posts in 4109 days
#12 posted 10-10-2017 05:03 PM
Whats the wood ?
JSMorgan
#13 posted 10-10-2017 05:08 PM
Rich: Yes, it is the quality of the surface and it is effecting the finish. As for wood prep: Sanded to 180, wiped with mineral spirits, applied dye stain, scuffed with 180, reapplied dye stain, applied shellac then applied stain. Dull finish in surface and when sanded, the area seems to spread. As I’ve said, I did a base cabinet and hutch the same way and it turned out okay.
JSMorgan
#14 posted 10-10-2017 05:56 PM
Mr Neil: Cherry
CharlesNeil
#15 posted 10-10-2017 06:15 PM
did you wipe /brush the shellac I respectfully disagree about black being a hard color ,its one of the easiest, There is only one color of black.
Its the sheen and top coat that make the difference . Most blacks are not black, they are very dark blues /greens .
I am surprised your dying Cherry black…
Let me respond more in the am. In a class at the moment
We can fix this .
showing 1 through 15 of 30 replies
