14" table saw blade for Oliver 232
Forum topic by jmcpadky posted 02-04-2011 08:09 AM 2871 views 0 times favorited 13 replies Add to Favorites Watch
View jmcpadky's profile
jmcpadky
7 posts in 2684 days
02-04-2011 08:09 AM
Hey, I have several 12” blades for my Oliver 232 table saw but they cut about 2 1/4” max. I need a good 14” blade for occasional cutting deeper than that. A good used blade would be OK, or what do you recommend as a source for new ones? Thanks, JMc.
13 replies so far
View Colin 's profile
Colin
93 posts in 2811 days
#1 posted 02-04-2011 09:00 AM
I would say ask whomever is sharpening your blades now. They could probably make you one or would know of someplace local for you.
-- http://www.columbiawoodscreendoors.com
View carlow's profile
carlow
10 posts in 2669 days
#2 posted 02-04-2011 10:52 AM
not familiar with the oliver232but my 12” table saw can easily do a100mm cut [4”]don’t know why yours can’t get close to that, if you want to go deeper than that i would seriously consider getting a bandsaw
-- carlow geelong australia
27250 posts in 3822 days
#3 posted 02-04-2011 01:55 PM
JMc, Forrest carries a complete line of 14” saw blades.
jmcpadky
#4 posted 02-05-2011 03:45 AM
Thanks for the sugggestions. FYI the oliver is a 1942 model with a direct drive motor and the diameter of the motor and thickness of the table decreases the usable size of the blade. Carlow, hope you’ve avoided the floods and typhoon (tends to make iron rusty). It’s an honor to speak with someone down under—would love to visit there someday…JMc.
View John Ormsby's profile
John Ormsby
1285 posts in 3737 days
#5 posted 02-05-2011 04:29 AM
I might have a few used blades that are in excellent condition. 14” blades that will fit your machine. What is the arbor size?
-- Oldworld, Fair Oaks, Ca
jmcpadky
#6 posted 02-05-2011 04:41 AM
John, it’s a 1” arbor. Thanks, JMc.
John Ormsby
#7 posted 02-06-2011 01:46 AM
JMc, I did a little digging around in the blade section and have found a couple of 14” blades. I know there are more. They are stored in an area that , right now, is a little difficult to get to. I have approximately 350 different blades. The blades I have found are in excellent condition with lots of carbide. One has I believe 100 teeth or more for fine cutting.
The 14” blades I have found so far have 30mm bore. I think there are a few that have a 1” bore. I will keep looking.
Also, I think MedicKen also whats a couple for his machine.
John
carlow
#8 posted 02-07-2011 05:23 AM
avoided the floods and this is the first time ever that i have had a green backyard in february[mid summer here]usually the backyard is a dust bowl by this time of year,but you guys are having a bit of a snow problem at the moment.seems you have your blade problem under control .did your team win the super bowl?
jmcpadky
#9 posted 02-07-2011 05:55 AM
John, I’m checking with my sharpening guy this week to see if he has or can fashion a blade for me. If you find something in your stash, I’d still be interested. Thanks.
Carlow, glad you missed the big storms—enjoy the green backyard! We also dodged the bullet with the big snowstorm—by about a hundred miles, but have had a cold, cloudy winter with several small snows—good for days in the workshop. Superbowl? Not every Yank is a football fan—just a quiet Sunday evening at home. But earlier we did have a nice salad and steak at….Outback! JMc.
View StumpyNubs's profile
StumpyNubs
7592 posts in 2800 days
#10 posted 02-07-2011 06:10 AM
Holy jeez- 14” is a big table saw blade! I say sell that sucker to a tool collector and get yourself a good 10” saw. If you want to rip thicker wood, use a bandsaw.
With that said, I also understand where you’re coming from. You have a great old saw and I hope you find what you need!
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
jmcpadky
#11 posted 02-07-2011 06:25 AM
Hey Jim, the old Oliver came from our Illinois Central Railroad Shops—a piece of local history. Band saw? Working on a 1960 model 81 Powermatic to bring her back to life, but that’s another story…JMc.
John Ormsby
#12 posted 02-07-2011 07:08 AM
JMc,
Ask your local blade sharpener if he can get a reducer bushing for the blade. It is easy to do. You only need to make sure the bushing is held securely by using flat washers on both sides of the blade on the arbor. See if he can get them in 30mm to 1” and 1 1/4” to 1” reducing bushings. This way you can use the blades I already have and save you a lot of money.
John
View Toolphan's profile
Toolphan
5 posts in 2679 days
#13 posted 02-08-2011 12:20 AM
These guys have a pretty decent selection. This is where I get most of my saw blades.
Toolphan
Power Tools
-- Toolphan
