How to attach a handle to a turned vessel
« back to Woodturning forum
Forum topic by grace123 posted 10-08-2017 11:20 PM 655 views 0 times favorited 3 replies Add to Favorites Watch
View grace123's profile
grace123
237 posts in 2878 days
10-08-2017 11:20 PM
I haven’t started this project yet. I have a question to resolve before I begin. My daughter-in-law collects pitchers and displays them around her house. I want to make a segmented turning in the form of a pitcher.
How do I create and attach the handle so it appears to be flush with the body of the pitcher?
Any tips and advice are greatly appreciated.
3 replies so far
View Loren's profile
10477 posts in 3763 days
#1 posted 10-09-2017 12:15 AM
For strength the handle should probably be
cut from a laminated blank. If you cut
it from one piece of solid wood it would
be a lot more vulnerable to breakage if
the pitcher takes a fall. Making the handle
should be simple. Just band saw the shape
and use rasps and files to round it off.
Joining the handle to the side it would
probably be a good idea to use mortise
and tenon joinery. Drill and chisel out the
mortises on the vessel and cut tenons to
fit on the handle. Usually when fitting
a tenon shoulder to a curved piece the
most prudent approach is to pare a flat
on the curved part.
View Wildwood's profile
Wildwood
2405 posts in 2250 days
#2 posted 10-09-2017 12:56 PM
One way might be to add brass or metal handle.
http://www.woodextension.com/images/WT-olive-urn.jpg
https://i.pinimg.com/736x/cf/ec/86/cfec86e20a58e8d11b54547070eda953--wood-turning-wood-design.jpg
Another way is to steam bend your handle to shape you want.
http://s3.amazonaws.com/finewoodworking.s3.tauntoncloud.com/app/uploads/2016/09/05152729/99929165_06_xl.jpg
Think you have chosen a very ardous task, good luck with it.
-- Bill
View Woodknack's profile (online now)
Woodknack
12329 posts in 2495 days
#3 posted 10-09-2017 05:13 PM
Another option would be using a piece of wood that was curved in the tree, a limb, a or bent trunk. That’s what I did for a broad hatchet handle.
